31 Users Online (30 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> rendering
Thu, Oct 6, 2005 at 3:57:53 PM | rendering
chrisd2
I am having problems with interference patterns when using Revits generated standard brick patterns and" tiling" when using Revits image patterns for roofing tiles. I have tried making the cube bigger but to no effect.
Thu, Oct 6, 2005 at 4:53:22 PM | RE: rendering
TomDorner
4.5 Stars: 25 Votes
You need to adjust the scale of the mapping. Making the cube bigger is only for visual reference when setting the material image mapping scale. I would recommend going to www.accustudio.com downloading and installing their material library and also taking a look at their Accurender tutorials. Remember, rendering with Revit is really rendering with Accurender which is included with the Revit software. HTH Tom P.S. Attached is a PDF I wrote for the Revit users group here in Minnesota that I lead. It is not a full tutorial on rendering, but gets you pointed in the right direction.
Fri, Oct 7, 2005 at 6:56:04 AM | RE: rendering
Will9000
4 Stars: 5 Votes
is there anyway to default download the entire library?
Realistic Rendering [ 1 2 ]
Thu, Aug 4, 2011 at 2:30:38 PM
25
2 Days Rendering...38% Complete 2009 Slow Rendering [ 1 2 ]
Wed, May 13, 2009 at 7:36:40 AM
22
09' Rendering Issue
Wed, Jun 3, 2009 at 4:22:52 PM
11
Going from Rendering in RA 2008 to Rendering in RA 2009
Mon, May 11, 2009 at 4:32:51 PM
help with rendering!
Wed, Aug 10, 2016 at 10:47:18 PM
Page generation time: 0.7060
