57 Users Online (55 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> graphical cut back distance
Fri, Jul 9, 2010 at 9:01:15 PM | graphical cut back distance
CNMSD
I'm placing horizontal roof bracing in between my portal frame beams and there seems to be no cut back distance (see attached) I've set this distance in structural settings but it doesn't work. Any way around this so I don't have to compromise my model by physically moving the bracing back?
Mon, Aug 16, 2010 at 7:20:31 AM | graphical cut back distance
gprakash
Is your horizontal bracing placed at the same level of portal beams?
Thu, Aug 19, 2010 at 11:14:35 PM | graphical cut back distance
CNMSD
Horizontal Bracing calls for SHS struts and rod bracing to be approx. 150mm below the top flange of rhe rafter. So in fact the bracing member actually passes under the top flange. Is this why?
Greyscaling elements at a distance?
Tue, Aug 16, 2011 at 7:30:52 PM
Graphical Column Schedule - Formatting
Tue, Jan 9, 2007 at 12:57:38 PM
Mon, Dec 10, 2018 at 5:58:55 AM
Graphical Column Schedule Fields
Thu, Nov 5, 2009 at 10:30:02 AM
Base Plates & Graphical Column Schedules
Mon, Feb 22, 2010 at 11:51:01 AM
Page generation time: 0.7165
