Forums >> Revit Building >> Technical Support >> Gross, Rentable, and Usable Floor Area
Fri, Jul 9, 2010 at 3:01:16 PM | Gross, Rentable, and Usable Floor Area
jsel13
Can Revit create a Schedule combining Gross Floor Area, Rentable floor area and Usable Floor area like the attached chart? i can do each one individually, but im not sure how to combine them without using Excel, which i'd prefer not to do. Thanks
Fri, Jul 9, 2010 at 4:02:19 PM | Gross, Rentable, and Usable Floor Area
TomDorner
4.5 Stars: 25 Votes
Sorry Revit cannot combine the data like shown.  You can use Excel by exporting Revit schedules as text and linking into Excel. Or you could do an ODBC export and link into Excel, Access or SQL Server.  Another option I prefer is ODBC export and link to Crystal Reports.
Just be careful using ODBC as all units are Metric via ODBC export so you need to do the Imperial conversion on the DB side.
Another case of Revit is a database and using other database tools is frequently the answer.
Edited on: Fri, Jul 9, 2010 at 4:03:42 PM
Tom
www.reviteer.com   http://twitter.com/Reviteer
Mon, Jul 12, 2010 at 9:05:26 AM | Gross, Rentable, and Usable Floor Area
jsel13
thanks for your help...
You'd think something so simple would be a little easier then jumping through all these hoops
Creating custom labels showing area in a titleblock.
Wed, Aug 7, 2013 at 10:40:49 AM
Rentable vs Gross area, gross area in practice
Tue, Mar 13, 2012 at 11:15:27 AM
Gross areas & Phasing
Mon, Feb 23, 2015 at 9:14:01 AM
incompatible area tags
Sat, Jan 14, 2006 at 1:57:46 AM
IFC export: Gross Area
Fri, May 29, 2009 at 3:01:19 AM
Page generation time: 0.7042
