99 Users Online (97 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Advice on creating a site plan
Fri, Jul 9, 2010 at 10:18:34 AM | Advice on creating a site plan
archie456
3 Stars: 1 Votes
Hi,
For our site plan, in AutoCAD we draw the whole thing out (road, paths, grass areas, gravel etc etc). And then put lots of nice hatches over them to create a good looking coloured site plan.
The client likes these.
So how to you achieve this with Revit (I'm a little new to this).
Could I create a toposurface for my site and then colour it up somewho?? Is there a better way?
I would appriciate any advice or tutorial.
Cheers.
Sun, Jul 11, 2010 at 5:46:28 AM | Advice on creating a site plan
archie456
3 Stars: 1 Votes
Anyone? - I'm sure there has got to be a better way of doing this in Revit??
Sun, Jul 11, 2010 at 6:08:35 AM | Advice on creating a site plan
4 Stars: 203 Votes
"And then put lots of nice hatches over them to create a good looking coloured site plan."
You can't apply surface pattern to your site BUT you have the "Filled Region" to solve your problem, check your HELP menu to see how to use it....
Also, check this: http://www.eaglepoint.com/solutions/workflow/office/landscape/landcaddforrevit.asp
Edited on: Sun, Jul 11, 2010 at 6:50:44 AM
Sun, Jul 11, 2010 at 3:29:52 PM | Advice on creating a site plan
archie456
3 Stars: 1 Votes
Thanks - I'll give that a try.
Edited on: Sun, Jul 11, 2010 at 3:31:52 PM
Mon, Jul 12, 2010 at 2:16:01 AM | Advice on creating a site plan
mcantwell
mcantwell Avatar
You can go some way using floors, ramps and / or pads. These take surface patterns.
Subregions will split the topo and that can be used to snap to for filled regions.
Mon, Jul 12, 2010 at 12:37:02 PM | Advice on creating a site plan
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
I divised this, see attached, technique for creating street work it is admittedly a little clumsy but it gives a fairly good result.
Mon, Jul 12, 2010 at 3:36:35 PM | Advice on creating a site plan
archie456
3 Stars: 1 Votes
Thanks for your advice chaps.
It does not look like I'll be able to achieve in Revit the 'good looking' site plan with hatches (especially gradient hatches) that I can in AutoCAD.
Unless there is something else I can do, I may use AutoCAD for the site plan and Revit for the building...
Mon, Jul 12, 2010 at 3:49:39 PM | Advice on creating a site plan
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
If you are are talking 2D revit can do most anything possible in AutoCAD
Mon, Jul 12, 2010 at 5:04:04 PM | Advice on creating a site plan
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Use walls and 'edit profile' for curbs and retaining walls. Create a temporary section near by if need be. You can also use an 'in-place family' to create other site objects that don't come with REVIT. Such as a 'sweep' to create a sloping curved curb or retaining wall.
You can also use annotative 'filled regions' to create site hatching. Don't fall back on your AutoCAD. Do it ALL in REVIT !!
Edited on: Mon, Jul 12, 2010 at 5:14:45 PM
Creating a Site
Sat, Apr 10, 2010 at 6:19:22 PM
14
site plan disappears intermittently
Thu, Mar 16, 2017 at 9:21:13 PM
Walls from multiple floors above showing in site plan
Wed, Oct 3, 2012 at 9:23:53 PM
creating a view from a specified area of a site plan
Tue, Jun 12, 2012 at 11:31:36 AM
Problem with Reigion Hatching on Site Plan [ 1 2 ]
Tue, Feb 25, 2014 at 4:19:16 PM
26
Page generation time: 1.6017
