84 Users Online (83 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Structural Column with magic circle
Thu, Jul 8, 2010 at 5:07:31 PM | Structural Column with magic circle
RicardoWright
Does anyone know how to get rid of this blue circle that shows up in all of my columns? The columns are in one revit file and appear normal there. But when it is linked into another revit project, the circles appear. Using Revit 2011. Thanks.
Thu, Jul 8, 2010 at 5:58:55 PM | Structural Column with magic circle
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
Go to visibility/graphics, check the box at the bottom left that says"show categories from all disciplines" ...what you're seeing is the structural analytical model.
 Ah. So since it's linked, (this is what the architect/consultants must do, not you) they'll have to go up to the "revit links" tab in VG, select the linked model, and modify the linked model's VG settings in there. Hope that helps.  Checking the box "show all categories from all disciplines" is the real key.
Fri, Jul 9, 2010 at 10:12:59 AM | Structural Column with magic circle
RicardoWright
Fantastic. Thanks for the help!
Structural Columns moving on their own
Tue, Jun 21, 2005 at 11:10:21 PM
Column shows a blue circle at axis
Mon, Feb 23, 2009 at 2:16:01 PM
Column shows blue circle on axis in plan view?
Tue, Nov 7, 2017 at 4:42:44 PM
Visibility graphics of a structural column
Mon, Aug 16, 2010 at 8:21:01 AM
Structural Column not working
Mon, Jul 2, 2018 at 10:20:10 AM
Page generation time: 0.4395
