76 Users Online (75 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Community >> Newbies >> Frameless shower glass door
Thu, Jul 8, 2010 at 2:47:42 PM | Frameless shower glass door
BYEBYECAD
I have trouble trying to get a frameless glass door in a shower enclosure. The door is hinged to a standard tiled wall and the other side is a half glass wall (see image).  I only found a glass doors for curtain walls but I don't think an exterior curtain wall in a bathroom is the solution.  Also I tried to create a glass door type but I can't eliminate the frame ( I get an error).  Any insights in how to solve this problem?
Thank you for your help
Thu, Jul 8, 2010 at 2:59:06 PM | Frameless shower glass door
Since we don't treat these as a door but as a toilet accessory, we created a simple foor based family....so can you.
Thu, Jul 8, 2010 at 6:00:42 PM | Frameless shower glass door
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
the simple answer is wall and forget about the hinges and such.
Thu, Jul 8, 2010 at 11:23:05 PM | Frameless shower glass door
BYEBYECAD
Thanks for the help. I created a new door from a general model template but instead of making it a floor based I made it wall based.  The model came up ok but the only problem I got was it doesn't attached to the wall. It is off the wall by 9/16". Any suggestions of how to solve it? I attched the file I created for reference.
 Thank you
Thu, Jul 8, 2010 at 11:25:40 PM | Frameless shower glass door
beaudavis
I'm new to revit, but finding curtain walls can substitue for many of the problems you have with other families etc
Fri, Jul 9, 2010 at 7:39:20 AM | Frameless shower glass door
I think people overuse curtain walls.  I generally want my project to list properly when exported.  There are some instances where you are just better off to use a CW but this is not one of them.
BYEBYECAD .... I think using a wall hosted template is wrong and will cause you problems as you have found out.  A floor based or none hosted template will work best.  If you don't want hindges or latch, then this is really simple.  Just a vertical extrusion - thickness as required and material set in the family.  One rectangle - height and materials set - done.
Fri, Jul 9, 2010 at 11:50:11 AM | Frameless shower glass door
BYEBYECAD
Thank you for the advice.  I did try to make it as a curtain wall but I agree with WWhub , I want my project to list properly specially when one is in the learning phase of revit.  That was my first family I created so I it was a good learning experience, but I will change it to as floor hosted family as indicated.
Regarding the problems with wall hosted family templates , is this a common occurrance? Is there information available I can read to learn how to solve it?
Thank you again.
Glass Shower Door
Thu, May 29, 2014 at 7:44:32 AM
Glass Shower Doors
Mon, Jun 16, 2014 at 8:58:13 AM
Frameless Glass Fence Panels
Wed, Oct 24, 2012 at 12:02:20 AM
Vertical Tile and Shower Frame and Glass
Wed, Feb 3, 2010 at 11:02:46 AM
Glass Edge Visability
Mon, Apr 21, 2008 at 7:09:45 PM
Page generation time: 0.6269
