48 Users Online (47 Members):
Forums >> Revit Building >> Technical Support >> Pedestal for HC automatic entry door
97 Posts No Rating |
Hello all, I'm looking to see if anyone has created, or found, a push button pedestal for an autumatic entry door? For an instance where the entry is in a storefront and there is no place to mount the automatic door opening button? I guess I could just create a family, but its easier to d/l one. I guess I'll get started. Thanks in advance.
I just uploaded a Key Pad Stand, mabe you can modify it.
Thanks mbsteve, but I'm still using Arch 2010... any chance you could repost?
This is a very easy family so why don't you just do it. GOOD TIME TO BEGIN It is nothing more than a vertical extrusion (post). Then if you want to add the keypad, you could do that on a face of the post. Decide what will host this if anything. If it might be outside, then maybe no-host.
just thought I give you a start, it might be 2010, can't remember when it was made, can't go back though, sorry
Rebar placement in concrete pedestal not allowed |
Tue, Aug 30, 2011 at 10:11:16 AM
see through door opening to door beyond |
Mon, Nov 2, 2009 at 1:46:12 PM
Automatic dimensions to door family defaulting to wrong side of door. |
Fri, Jul 22, 2016 at 9:58:33 AM
Automatic Sliding Glass Door |
Mon, May 2, 2005 at 10:59:47 PM
Sidelight Constraint |
Fri, Apr 28, 2006 at 3:09:47 AM
Members: | 2037326 | Objects: | 23017 | Forum Posts: | 152210 | Job Listings: | 3 |
