101 Users Online (99 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Key Schedules/Finish schedule
Thu, Jul 8, 2010 at 1:25:53 PM | Key Schedules/Finish schedule
Dimplesaur
I currently have my room finish schedule referencing my material key schedule.  It works great when I have one finish per room, however what do I do when there are multiple finishes in one room?
We have tried writing See Remarks and then in remarks it would say "See finish plan" Or something along those lines.  However since the materials in the room schedule reference the room finish materials key, I would have to add a line in the key schedule that says "SeeRemarks" in order for that text to appear in the Room schedule.  The problem is then you have a line in the material key that reads "See Remarks" and there is no way to hide this line.
Any suggestions on how to take one this issue?
Thu, Jul 8, 2010 at 1:35:21 PM | Key Schedules/Finish schedule
Key schedules can be a problem...  When you use a schedule key, the items only point to the key and none of the parameters are really assigned to the item.  You have to understand that if something is assigned a key schedule it is all or nothing for those parameters in the key.  But - If you don't assign the key schedule... or if it is only a partial key schedule, then those items not assigned can be altered.
Version 2009 - Shared Parameters and Key Schedules
Fri, Jan 30, 2009 at 1:49:25 PM
Key Schedules and Shared Parameters
Tue, Oct 7, 2008 at 3:14:43 PM
Tag room schedule key info
Wed, Sep 11, 2013 at 11:13:01 AM
Finish Material Schedule
Tue, Nov 29, 2005 at 12:31:59 PM
finish/ material schedule
Fri, Apr 25, 2014 at 12:30:26 PM
Page generation time: 0.5808
