97 Users Online (96 Members):
Forums >> Revit Building >> Technical Support >> REINFORCING MOVES MODEL
36 Posts No Rating |
ok, here is the deal. i put in footing (pile cap with piles). i drew in reinforcing, but when I tried to copy it around (to get the correct spacing) it moves the footing.
why is this ( i know it does it because it is hosted by the footing), im trying to find out how to copy the rebar around. maybe how to unhost and rehost an object.
![3.5 Stars: 2 Votes](/images/stars_3.5.gif) |
When you copy the reinforcing are you disjoining and removing any constraints that be on it?
Typically, thats what is causing it to happen at our office.
there are no constraints on it. i am only sketching rebar, then going to the section 90 deg from where I sketched it ( to space it correctly) and the footing moves).
i think I confused you somewhat, the model doesn't move, only that one footing.
this may help, or just confuse people. i can move the rebar fine, only copy causes the problem.
see attached file
visibility of reinforcing from linked structural model in architectural sections |
Thu, May 29, 2008 at 3:44:37 PM
Reinforcing Tags |
Thu, Jan 2, 2014 at 1:15:45 PM
Test Labels with psuedo dimension lines |
Tue, Sep 20, 2005 at 9:45:16 PM
can I model a rebar inside a model slab |
Thu, Jan 10, 2013 at 12:29:27 PM
2D Reinforcing Family - not recognizing View Scale |
Tue, Jan 2, 2018 at 2:16:32 PM
Members: | 2017134 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
