59 Users Online (57 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Callouts are funny
Tue, Jul 6, 2010 at 9:20:04 PM | Callouts are funny
echo1
I have been stumped for a while and was unable to find anything searching the old forum threads...  I have in front of me now an elevation that should have two building section callouts in it.  Only one shows.  I checked the VG and for hidden objects.  It does the same thing on the opposite elevation where the same two should building section callouts should show.  A cross directional section does show both building sections in question.  I tried adjusting the extent of the section to make sure it crosses the elevation plane.
But in another post to a similar problem:
site moderator
Joined Tue, May 16, 20065427 Posts3.5 Stars from 78 Votes
Change your scale to a larger one and see if they rea-appear.  If they do, then you have to change the setting for hiding the callout in the smaller scales.
 So I tried this and the both sections show up when I change the scale to anything larger or smaller than 3/16" = 1'...  I have been using Revit a good while but I am not sure what WWHub is referring two with hiding (or not) callouts by scale.  I am using old fashioned 2010 Revit Architecture.  All sections and elevations are at 3/16" scale.
Thanks!!
Wed, Jul 7, 2010 at 9:51:06 AM | Callouts are funny
echo1
Still stumbling.
 I tried recreating the problem in a new file but without success.
I place a new section in the area... but it has the same issue.
I change the callout to a wall section, still dissapears when it goes to 3/16" or 1/8" or smaller.
Wed, Jul 7, 2010 at 10:08:28 AM | Callouts are funny
echo1
SO NOW I find the hide at scales courser than option....  I scanned the section cut properties several times before and missed this.  Apparently building section automatically set this to the scale they are created in.
 I am not sure how this basic function has eluded me.. but now I know and knowing is half the battle.
Are Callouts Vew Specific?
Wed, May 12, 2010 at 3:56:07 PM
HELP! callouts are not visible!!
Sat, Feb 16, 2008 at 12:17:22 PM
Callouts and Callout Sim Views
Thu, Sep 12, 2013 at 10:41:58 AM
multiple section callouts
Wed, Jun 4, 2008 at 9:04:19 AM
Visibility of callouts
Fri, Nov 11, 2011 at 3:04:49 PM
Page generation time: 0.2018
