Forums >> Revit Building >> Technical Support >> import label anootation to generic 3d model
43 Posts No Rating |
i am trying to adapt the revit family Ladder to make a stud wall where rungs and stud have similar parameters but the "number of rungs" label is snagging me,how do incoperate it in a 3d model load family into generic model restricts import-excludes annotation label? see clip for explanation http://www.youtube.com/watch?v=qri7zaH02x8 shared parameters?
That "number of rungs" is the parameter from the "Array, after you create the array, select one element then select the line with the number (2), in the options bar select "Label / Add parameter", then give it a name (number of rungs), and a group parameter like you can see in the images.
i think i understand the quantitiyparameter but the use of it in a 3d template family is the problem it works in 2010 version but not in 2009? label with number (quantity properties) -right klik- edit label and your off but not in 2009? (or have i missed somthing-i dont get the option edit label in 3d template family in 2009) see (1000 words) clip http://www.youtube.com/watch?v=8NfO5iS2yeE
could some one please explain? the url captured the right click edit label add parameter fuctioning in revit 2010 so i thought it was a 2010 update problem now it(revit2010)refuses to right click edit label as shown in clip it was ok earlier today now its not allowing right click edit label? can i blame the tools?
SELECTION PROBLEM click one item in array and right click number of array and you will not get the edit label option drag and click all items in array and it works http://www.youtube.com/watch?v=MuT3QK7bYOQ thanks yuor wellcome dont mention it
No need that, you must SELECT the LINE of the array and not the number, watch this: http://screencast.com/t/NzFkYTlm
thank you
hi perhaps you can throw light on the following door swing problem the family crane/logistics/site has a boom angle parameter that moves the boom. a simple extrusion i and trying to copy this into a door swing but find i over constrain or lose the shape of door i found sweep worked better than extrude but still run into problems attaching hinges to door perhaps it is to do with the site template but in the site template(building a wall and door) it does not work for me either the url shows the question better--trying to copy the boom swing parameter but running into problems
the above is another clip of the same problem
Ok, watch this: http://screencast.com/t/NTNjZDRh
it does not flex very well? i find it very difficult to repeat what is on the video the extrusion starts with 2 locks on the first line--i cant get that --as soon as i move cursor the locks banish perhaps thats the problem all attempts lead to remove constraints (on 1 lock) is that a tutorial seris? thanx
"the extrusion starts with 2 locks on the first line--i cant get that --as soon as i move cursor the locks banish perhaps thats the problem" - That's because when you are creating the line, first you may uncheck the "CHAIN" mode in options bar, when you do that you can lock those padlocks. "is that a tutorial seris?" - NO, i create that video just for you.
thanks a lot for the clip i s am still struggling with it need to look at basic constraining and dims again still comes up remove constraints-extremely fragile http://www.youtube.com/watch?v=LJ7irIs4cEU&feature=channel
Ok, watch this: http://www.megaupload.com/?d=S8U8EPLM
thanks again for your help very explicit i think the problem to some extent is the tools why is it so difficult to snap point on ref line in dim mode a lot of what needs to be learned seem to be a case of trial and error approach their is no documentation that i know explaining these problems? thanx again /youve been very helpfull
