68 Users Online (67 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Cut Pattern Issue
Fri, Jul 2, 2010 at 3:28:55 PM | Cut Pattern Issue
cadman7577
1 Stars: 1 Votes
Ok so I go to material editor and click the drop down for the Cut Patterns they are all there.  Then I go back to the drawing and click on a wall / edit / structure / material.  The cut patterns are all listed, but just have white boxes out to the side no patterns.
This is only happening in one file and I have tried "Transfer Standards" and I still get the same thing.  So I don't know if it's a simple setting I'm over looking or what.
Please see attached.
Any help would be greatly appreciated.
Fri, Jul 2, 2010 at 3:30:55 PM | Cut Pattern Issue
cadman7577
1 Stars: 1 Votes
Sorry....Using Revit 2011
cut pattern issue
Wed, Jan 28, 2015 at 3:53:15 PM
Cut Pattern for Curtain Panel Not Showing in Plan
Fri, Sep 5, 2014 at 6:25:57 PM
loss of cut pattern
Fri, Nov 28, 2014 at 8:47:10 AM
ARCHITECTURAL COLUMN ISSUE
Thu, Feb 13, 2014 at 8:50:50 PM
Stiar cut pattern or fill pattern.
Sun, Feb 19, 2006 at 11:46:36 PM
Page generation time: 0.9612
