82 Users Online (81 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> General Discussion >> Wishlist >> Wish List - Please make suggestions
Thu, Jul 1, 2010 at 11:52:16 PM | Wish List - Please make suggestions
Rams
3 Stars: 3 Votes
Hi All,
I am confident that in BIM softwares especially Revit is very much capable of modeling & construction documentation process of engineering phases. Now when it comes to project documentation then i would you all to put some thoughts:
1) Records for documents like RFI (request for Information) & TQ (technical queries) are generally missing from BIM project files. Document controller has to manually take care of such stuff. - Please let me know your points
2) Documents like approval from planning application authority, project based specification etc are not of part of BIM right now
Can you all please let me know what else you believe should be available in BIM? Any suggestions, thoughts etc. will help me to plan the strategy for upcoming projects in my company.
Thanks in advance,
Rams
Now on the implementation stage....
Fri, Jul 2, 2010 at 6:46:14 AM | Wish List - Please make suggestions
I don't believe either of those belong in the BIM file but with it.  A DWF can be used to collectively hold these documents along with a 3D image if you want everything in one file.
Fri, Jul 2, 2010 at 6:57:49 AM | Wish List - Please make suggestions
Rams
3 Stars: 3 Votes
Thanks WWHub,
Actually I am looking for a common platform where apart from BIM execellence we can integrate rest of the documents also. I am sure other users will also have something in their mind as well
Thu, Aug 19, 2010 at 9:43:49 AM | Wish List - Please make suggestions
Quincer
Making Supplemental Drawings in Revit is the worst.  If you need to make a change on a plan or detail, normally you wouldn't resubmit the entire sheet, rather include a portion of a plan or detail on a small 8 1/2 x 11.  The only way I found to do that in Revit is to first make your change, then duplicate the view with detailing, crop the visible region and annotation before moving the view to a new sheet.  And if you need to make a change, you need to make the change in both views or recreate you suplemental drawing view all over again.  Most of the time the annotations dont come across the way you want it, and if it's a section, a new tag shows up on your floor plan in every view at that level.
Revit needs to come up with a "paper space" tool like Autocad uses.
wish list??
Wed, Aug 4, 2010 at 12:48:59 PM
Railing not shown in list
Mon, Jun 30, 2014 at 4:25:57 PM
How to print shortcut list
Thu, Aug 26, 2010 at 1:59:50 PM
Sheet List Parameters
Thu, May 1, 2014 at 2:22:05 PM
I'm trying to Make a Roof Top Unit Schedule. Please Help
Thu, Feb 14, 2008 at 12:21:19 PM
Page generation time: 2.5164
