Anybody familiar with Autodesk Image Modeler? My questions is Can you import a model from Image Modeler to Revit? Thanks
![4.5 Stars: 25 Votes](/images/stars_4.5.gif) |
Not directly to Revit. It will go to .dwg which can then be brought in as a mass family and used to build a Revit model using faces. From the Autodesk FAQ's: How does ImageModeler 2009 integrate with other Autodesk products? Improved support for DWG files provides faster, more accurate export of data to other Autodesk software such as AutoCAD®. The FBX®‐based RecognizeTM scene‐loading technology enables ImageModeler users to quickly and accurately export geometry, textures, and cameras. Also, the Autodesk FBX file interchange format allows users to easily transfer assets to 3ds Max, Maya, and Autodesk® MotionBuilder® software, as well as any other content creation package that supports FBX. What are the imports and exports can be done with ImageModeler 2009? Here is the list of ImageModeler imports and exports. Import: • OBJ: 3D objects and textures Export: • FBX: 3D points and objects, textures, cameras • Maya (.ma): 3D points and objects, textures, cameras • OBJ: 3D objects and textures • DWG: 3D points and objects, measures
