Forums >> Community >> Newbies >> floor finishes
34 Posts No Rating |
May be a simple question, but, What is the best way to show two different floor finishes within the same room? It doesn't seem like a new floor boundary may not be the best way, I also tried split face, which allowed me to apply separate finishes to different zones, but if I cut a section through each zone, it still shows as the floor element properties. See example attached.
may have found the answer...thin floors? create a floor which includes sheathing and structure only, then apply the finishes of my choice to the correct area? Any further explanation would b great.
56 Posts No Rating |
use shortcut 1) ALT - M - SF ->this will turn on the divide option to cut 2) click which surface you want to edit 3) draw what you want to separate 4) ALT - M - PN -> This will enable the "Paint" option 5) choose the material 6) paint the divided surface into whatever you want Hope this is what you mean.
Thats what I did in the illustration from post #1, but it doesn't carry thru with the section view. The finish floor is still based on the element properties. I need the quickest way to change the finish floor, without having to create separate "floor" elements. Thanks.
Floor Finishes not showing up in Revit 2013 |
Thu, Dec 25, 2014 at 5:52:37 AM
Floor Finishes |
Mon, Oct 15, 2012 at 10:42:34 AM
floor finishes |
Wed, Jul 12, 2006 at 7:41:46 AM
How to have seperate floor finishes? |
Tue, Apr 12, 2011 at 7:12:39 AM
floor finish limits |
Tue, Dec 19, 2006 at 11:59:08 AM
Members: | 2100928 | Objects: | 23173 | Forum Posts: | 152292 | Job Listings: | 3 |
