93 Users Online (92 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Community >> Newbies >> Problem loading Mullions
Wed, Jun 30, 2010 at 9:31:56 PM | Problem loading Mullions
BYEBYECAD
Hello RevitCity community:
 I'm a recently converted Revit user (2 weeks) and I'm learning it only through blogs and video postings. So far I'm doing great with my first project in revit and I've done a lot, but I just stumble with a problem that I can seem to solve.
I'm trying to create a curtain wall. I drew the gridlines with no problem on an empty piece of glass . Then I tried to add a mullion and revit says "no mullion family has been added to the project.Would you like to load one now? I said yes, then it took me to the library, then I chose profile, curtain wall and then pick the Curtain Wall-Rectangular-Center file.  Then when I tried to add a mullion ask for the same question again.
What am I doing wrong? I know it may be something basic but I can figure it out
Thank you for the help
"CAD is dead long live Revit"
Wed, Jun 30, 2010 at 9:56:32 PM | Problem loading Mullions
TomDorner
4.5 Stars: 25 Votes
Mullions are system families that cannot exist outside the project.  If they have been deleted from your template that started the project or from the project itself, you will have to load them in from another project.  Once a mullion is loaded into the project, only then can it be assigned a custom profile which is nothing more than a 2D line family.  Even then only rectangular and circular mullions can use the mullion profile.  Other mullion types such as corner will not accept a mullion profile.
To fix your problem, start a new project with the default Revit template.  Create a curtain wall in the new project and place some mullions on it.  Then select the curtain wall [hint: just the wall not the mullions and grids as those elements are hosted to the curtain wall itself]  Copy the curtain wall to the clipboard.  Switch to your real project and paste the clipboard with the curtain wall in. [hint: hit the finish button on the options bar]
Once you have the curtain wall in your real project you may delete it.  You should now have mullions in your project that you can modify/duplicate.
Tom
www.reviteer.com   http://twitter.com/Reviteer
Wed, Jun 30, 2010 at 11:56:31 PM | Problem loading Mullions
BYEBYECAD
It worked. Thanks so much.
Sun, Aug 14, 2011 at 7:07:14 PM | Problem loading Mullions
solevidal
thanks,it worked for me too
soledad
Fri, Feb 20, 2015 at 1:55:49 PM | Problem loading Mullions
Laurendavis33
This worked for me too! Thanks!
Problem loading components
Mon, Sep 28, 2009 at 3:43:41 AM
Adding mullions to curtain walls
Thu, Jan 27, 2011 at 12:08:53 PM
Adding mullions to a window
Wed, Dec 14, 2016 at 10:19:20 AM
Adding mullions to a fixed or casement window
Mon, Feb 27, 2006 at 1:52:14 PM
problem loading components
Sun, Apr 26, 2009 at 2:21:19 PM
Page generation time: 3.1372
