47 Users Online (46 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> 2D Family Help
Mon, Jun 28, 2010 at 4:41:55 PM | 2D Family Help
NkatOmg2
NkatOmg2 Avatar
4 Stars: 1 Votes
I need help.
File>New>Family>Detail Component Template
I want to draw a simple 2D stretchable side view of a Shear Connector.  I set up my Reference Planes, I draw my object, set my Dimension with an Instance Parameter and it will not work.  I am posting what I have done.  This is just a simple detail and I cannot get it to work.  Please walk me through the steps of making this work, I just don't get why it will not work.
I have tried using single lines.  I have tried using a Masking Region.  I have dimensioned to the Reference Planes.  I just whipped out a 3D parametric window family today but cannot get something as simple as a stupid 2D Shear Connector.
Any in-depth help would be great from you all.  Thanks.
 I use Autodesk Revit Structure 2011
 My songs: http://nkat.newgrounds.com
Mon, Jun 28, 2010 at 5:20:59 PM | 2D Family Help
TKennedy
4 Stars: 7 Votes
I added another ref plane at the bottom of the head (3/8" to the right of your left hand ref plane), then in the masking region sketch locked the lines to those ref planes using the align command. That seemed to make it work. Generally objects seem to automatically move with ref planes when they are close (or on) them, I don't know why they aren't here.
Mon, Jun 28, 2010 at 7:51:50 PM | 2D Family Help
mcantwell
mcantwell Avatar
This is using a line based detail item
Matt
Tue, Jun 29, 2010 at 11:45:39 AM | 2D Family Help
NkatOmg2
NkatOmg2 Avatar
4 Stars: 1 Votes
TKennedy:  Thanks for taking a look at this.  I also do not know why it did not stretch when Locked onto the Reference Planes.  I took a look at mcantwell's posted Family.  He has Locked everything that falls onto a Reference Plane and then constrained anything that is not with dimensions.
mcantwell:  Thanks for your time.  This is a really nice family.  It works great.  I think you should upload it onto the site - I don't want to take the credit for it.
Thanks again.
Tue, Jun 29, 2010 at 5:34:58 PM | 2D Family Help
mcantwell
mcantwell Avatar
One thing that I would avoid - not sure if it was a factor - was the reference planes within the filled region. Messes with your head a bit until you find them.
PS not something I use so feel free to upload
Edited on: Tue, Jun 29, 2010 at 5:37:34 PM
Create a family that includes another family
Tue, Oct 11, 2022 at 12:32:18 PM
Can you use an IFC file in a family. or use one like a family?
Tue, Aug 7, 2012 at 4:27:00 PM
14
Detail Family Line weight sub-catoagories gone when family put into project
Tue, Aug 30, 2016 at 6:52:17 AM
11
"Can't Regenerate Family ____. Edit Family to modify it." Error message
Wed, Aug 26, 2020 at 11:19:36 AM
Text(family #1) not showing after loading into family #3
Mon, Jan 19, 2015 at 2:43:21 PM
Page generation time: 2.5767
