61 Users Online (59 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Beam not showing in Plan View no matter what I try
Mon, Jun 28, 2010 at 9:43:23 AM | Beam not showing in Plan View no matter what I try
ksmith
Hi
I have place a beam in my model but I cannot get it to show in plan view no matter what I tweak. I have tried adjusting the view depth, detail settings for course, medium,  fine etc, but nothin seems to work.
Here is the error message I get:
......None of the created elements are visible in Floor Plan: Phase 3 / beam level at top View. You may want to check the active view, its Parameters, and Visibility settings, as well as any Plan Regions and their settings......
Any ideas please
Thank you
Kirk, Using Revit 2010
USING REVIT 2011--- This old builder is determined to Learn Revit no matter what it takes.
Mon, Jun 28, 2010 at 9:56:26 AM | Beam not showing in Plan View no matter what I try
Bimman
Bimman Avatar
1 Stars: 2 Votes
sounds like the view you are in is not the correct phase for the item you are tring to place. check you phase and phase filter settings. set them to the correct selections and your beam should show up.
PWD
Mon, Nov 29, 2010 at 7:00:10 PM | Beam not showing in Plan View no matter what I try
tutu7931
same here!!!
NEED HELP ASAP....
I have both revit Arch and Structure, try to fix lots of setting but ain't work!
Tue, Nov 30, 2010 at 8:24:40 AM | Beam not showing in Plan View no matter what I try
gdoherty0102
3 Stars: 2 Votes
First thing is first.   Click on the light bulb, can you see it there?  I am asssuming not, so then you have a few options, check your view range, as you have said you have.
One way I like to double check this is by going in to a 3D view and orienting the 3D view to the plan that I can not see something.  Can you see it in that 3D?  If not can you change the section box to make it visible?  If it is visible in 3D then it may be that your phase is incorrect...do you have new, old, existing, etc phases on your project?
Try applying a view template from one where you see beams and see if it shows up.
Also may try playing with the view dicipline.
Sat, Apr 25, 2015 at 7:04:47 PM | Beam not showing in Plan View no matter what I try
JohnCullen
This happened to me too. Found all I had to do, assuming other things mentioned were checked was to set my DETAIL LEVEL to MEDIUM. So stupidly simple. Wasted 15mjinutes of life working it out.
They really need to bring back layers.
Thu, Nov 5, 2015 at 4:29:31 AM | Beam not showing in Plan View no matter what I try
lindaBIM
Thanks very much.  Changing the detail level to medium fixed the problem
Edited on: Thu, Nov 5, 2015 at 4:30:02 AM
Revit 2014 - railing showing in plan view
Wed, Sep 3, 2014 at 1:04:10 PM
Roof Plan not Showing in Site Plan
Wed, Jul 12, 2017 at 12:03:32 PM
11
Beams showing above in plan view
Thu, Sep 4, 2008 at 11:18:12 AM
Controlling Beam Lines in plan view
Thu, Sep 25, 2014 at 10:48:47 AM
Structural Beam Invisible Partial In Plan View
Tue, Mar 20, 2018 at 4:39:48 AM
Page generation time: 1.1570
