80 Users Online (78 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Multidirectional moving of objects w/in families
Mon, Jun 28, 2010 at 9:04:05 AM | Multidirectional moving of objects w/in families
fairladyz47597
I'm trying to learn how to edit families and I've noticed that I can't seem to move objects in certain planes.
 For example, I drew a rectangle in plan view and extruded it.  While in plan view, I can move the box freely.  However, when I switch to elevation view, I am constrained to moving the box only left and right.  I cannot move the box up and down.
 I realize that you can just adjust the parameters and the box will move in the Z direction accordingly.  However, you are not given this option in a shape that is created with the sweep tool (sweep-created objects seem to be locked to the reference plane).
 Any advice is appreciated!
Mon, Jun 28, 2010 at 9:06:47 AM | Multidirectional moving of objects w/in families
fairladyz47597
Nevermind!
Mon, Jun 28, 2010 at 9:08:35 AM | Multidirectional moving of objects w/in families
xzavoral
If you click on the Extrusion, there will be small symbol that is Clickable, that's what keeps it on reference plane where it was created ... if you click on it -> it dissappears and you can freely move it in elevation view.
Moving Annotation Symbols without moving objects
Mon, May 23, 2011 at 6:39:43 PM
Converting ArchiCAD objects into Revit families
Thu, Jan 17, 2013 at 9:43:29 AM
Transparent Families
Thu, Jul 15, 2010 at 8:35:26 PM
Creating Revit Families fro mCAD
Fri, Mar 4, 2011 at 3:57:34 PM
How to Scale Objects in Revit
Fri, Aug 25, 2017 at 1:13:47 PM
Page generation time: 0.5908
