79 Users Online (77 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Design Options
Fri, Jun 25, 2010 at 9:20:27 AM | Design Options
xzavoral
Hi,
I need a little help with design options in my project.
I have basic model. Than i created 3 (A;B;C) design options in 1 set. I selected some parts from the basic model and added them into design option "A". But then i realized that i selected 1 part that i need in basic model. I know i can do "Undo". But is there any way to put that part back to basic model ?
I found option to put whole option "A" but destroying B and C in process. I just need to give the part back to basic model.
And second problem:
I created for example 1 type of door and the other design option are wider doors. But i need to put some text to describe them. Is there a way to add text fields into design options?
tnx fro any help or ideas
Fri, Jun 25, 2010 at 9:48:27 AM | Design Options
You can copy paste from the option to the main model.
Text is view dependent (unless its a symbol).  With design options, you will want to set up which option shows in you VG sttings.  Then just use multiple views with the different options and place associated text/tags/dimensions in those views.
Mon, Jun 28, 2010 at 2:43:31 AM | Design Options
xzavoral
But when i do:
1) Selection
2) Copy
3) change Design option to option "B" (from A)
Copy/Paste option disappears and the only way is to "CTRL-V", it wouldn't be so bad, but when i do it, i dont have the option topaste it on the same place from which i was copying that.
Any way how to resolve this ?
Mon, Jun 28, 2010 at 3:55:46 AM | Design Options
gebber
gebber Avatar
5 Stars: 4 Votes
In RAC 2011 You have this option (to paste at the same place).
When using the paste comand you do have the align option wich can be used for the whole selection in the older versions.
Mon, Jun 28, 2010 at 4:27:40 AM | Design Options
xzavoral
ah, ok
I use RAC 2010, and i know the align but its not here for copying from 1 option to another, only in simple copying.
I ordered Trial for 2011 since we're not on subscription for RAC yet, hope it will solve my issue.
tnx for help
Design options issues
Thu, Mar 2, 2006 at 10:35:32 AM
Design Options
Wed, Dec 24, 2003 at 10:33:52 AM
Titleblocks & Design Options
Mon, Dec 8, 2008 at 2:06:34 PM
design options tied to other objects (version 2008)
Tue, Apr 1, 2008 at 6:17:37 AM
Text In Design Options
Fri, May 28, 2010 at 3:25:08 PM
Page generation time: 0.8383
