Forums >> Revit Building >> Technical Support >> Stair Riser Profile
Is it possible to create the attached stair profile? The closest I can get is having the entire riser slanting instead of just one side. I can not use monolithic stairs because we are offsetting the stringer and I believe monolithic stairs are incapable of doing that. I am using Revit Architecture 2010. Thank you!
I suggest downloading the most definitive guide on stairs from Phil Read. http://dl.dropbox.com/u/125962/AB114-1.pdf Phil worked for Revit before purchased by Autodesk and continued to work for Autodesk for a number of years. He is also co-author of the new Mastering Revit book. His blog: http://www.architecture-tech.com/ Hint: probably best done with a nosing profile that is the complete tread. I believe Phil has an example. ekoorb: please sent me a private email as I'm looking for a Revit enabled architect in the Nashville area. Visit my website below. Edited on: Fri, Jun 25, 2010 at 9:12:28 AM
Edited on: Fri, Jun 25, 2010 at 9:15:47 AM
" Is it possible to create the attached stair profile? The closest I can get is having the entire riser slanting instead of just one side. I can not use monolithic stairs because we are offsetting the stringer and I believe monolithic stairs are incapable of doing that. I am using Revit Architecture 2010. Thank you! " what do you mean by "having the entire riser slanting instead of just one side"? isn't the entire riser slanting in the image you posted.
I apologize if I wasn't clear. In section I would like the exterior of the riser to slant, but the interior to be vertical. I believe the pdf that Tom posted answered my question. I will try making a custom nosing that will act as the riser as well. Thank you.
" I apologize if I wasn't clear. In section I would like the exterior of the riser to slant, but the interior to be vertical. I believe the pdf that Tom posted answered my question. I will try making a custom nosing that will act as the riser as well. Thank you. " oh, i understand now. thanks for taking the time to explain that to me. i think Tom is correct too.
Riser profile? |
Mon, Nov 10, 2008 at 4:16:37 PM
PRECAST STAIR BEGIN WITH RISER LOOKS INCORRECT ON PLAN |
Fri, Sep 2, 2016 at 7:03:03 AM
Simple Stair Nosing error |
Thu, Mar 5, 2015 at 9:15:24 PM
Stair - Cut Profile |
Wed, Sep 14, 2011 at 1:36:18 AM
Stair riser - custom |
Tue, Jan 14, 2020 at 5:55:29 PM
Members: | 2119259 | Objects: | 23205 | Forum Posts: | 152300 | Job Listings: | 3 |
