70 Users Online (69 Members):
Forums >> General Discussion >> Revit Project Management >> Has anyone encountered "user"?
6 Posts No Rating |
I have about 4 worksets that show up as borrowed by "user". I have no idea how to relinquish this user. Any ideas? Thanks, Grace
Easiest fix - make a new central. But the real question should be - Who is setup as "user"? Have everyone look under the "r" and options to see what their user name is. Someone is not setup.
![4.5 Stars: 25 Votes](/images/stars_4.5.gif) |
No need to make a new central file. Instead change your user name in Revit to 'user', then create new local file, do a sync to central and relinquish all worksets and borrowed elements. Be sure to change your user name in Revit back to your original real one. But....as WWHub says make sure you understand who the 'user' is. By default Revit uses your Windows login ID for the Revit user name so if some is logging in as 'user' that is your answer. Even more though make sure that there is not more than one 'user' which can happen if more than one person is using the generic login of user on Windows.
6 Posts No Rating |
Worked like a charm. Thankyou.
New Revit User"DevilsRevit" |
Tue, Jan 15, 2013 at 7:33:26 AM
changing the "family" and "type" names |
Mon, Apr 2, 2007 at 5:33:49 PM
RevitMEP 2010 - Fixing Errors - "Check Duct Systems" + "Check Pipe Systems" |
Fri, Sep 18, 2009 at 11:59:29 AM
When I copy an "existing" element it reverts back to "new construction." |
Mon, Jun 16, 2008 at 2:38:24 PM
What happened to "activate dimensions"? |
Wed, Jul 1, 2009 at 2:34:44 PM
Members: | 2017201 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
