63 Users Online (62 Members):
Forums >> Revit Building >> Technical Support >> Import .pat file
2 Posts No Rating |
I have downloade a .pat file and saved on desktop. i now want to import into my Families library. Can someone help on this one please.
![eldados Avatar](user_avatar/6083.jpg)
![4.5 Stars: 8 Votes](/images/stars_4.5.gif) |
Sure! I assume yu are on Revit 2010/11 Go to your Annotate tab and select a Field Region --> Edit Type...--> Duplicate Under the Graphics click on the fill pattern (you will need to click on the far right of the pattern name to bring up the Fill Pattern window) Click New to bring up the new pattern window, in there select Custom and then Import, browse to your Pat file. Tip: 1. you might need to edit the import scale to get the correct scale for your pattern. 2. make sure you select either Drafting or Model pattern and that your .Pat file is the right category. HTH, let us know if you get stuck
![coreed Avatar](user_avatar/14568.jpg)
wow!! Eldados good to see you're O.K. man
2 Posts No Rating |
Awesome thanks for that **
1 Posts No Rating |
THANK YOU SO MUCHH!
0 Posts No Rating |
Thank you for your help.
0 Posts No Rating |
Where is the PAT fiels stored in Revit 2021? I am trying to find it on the system. Thank you.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2021/ENU/Revit-Customize/files/GUID-69192B73-394C-4EC6-B885-0A2945CBEB7A-htm.html
Import PAT File |
Tue, Dec 14, 2010 at 9:42:43 AM
Revit 2012, cannot import custom pattern from .pat file |
Wed, Dec 30, 2015 at 8:31:18 PM
Upload? , Import? download?, graphics?, hatch?, File Pat |
Fri, Aug 7, 2015 at 11:37:58 AM
Need help with PAT File URGENT! |
Fri, Aug 31, 2012 at 8:37:06 AM
Can't import .pat file |
Wed, Oct 6, 2010 at 8:28:18 PM
Members: | 2016897 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
