42 Users Online (40 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Roof Cricket
Wed, Jun 23, 2010 at 12:24:39 PM | Roof Cricket
mezdez24
5 Stars: 2 Votes
I can't figure out this roof cricket behind the finial. Any suggestions would be greatlly appreciated! Thanks in advanced!
Wed, Jun 23, 2010 at 12:47:06 PM | Roof Cricket
4 Stars: 203 Votes
Can you explain a little bit what are you talking about? "what roof cricket behind the finial"?
Wed, Jun 23, 2010 at 1:33:10 PM | Roof Cricket
mezdez24
5 Stars: 2 Votes
I wasn't able to save the file smaller than 2mb!? Here are Images of model.
The cricket behind the finial needs to slope down to both points that are circled.
Thu, Jun 24, 2010 at 11:34:28 AM | Roof Cricket
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
The model you posted with the finial in a niche of the wall, will work. I think what your concern is the way it will look on the side view. I would add a cricket with a ridge centered on the finial wall, and disappearing at the ends. This can be done by modifying the roof or adding a separate roof over to create the cricket. Give it a low slope, could be made of metal.
Fri, Jun 25, 2010 at 12:56:09 PM | Roof Cricket
mezdez24
5 Stars: 2 Votes
thanks for the response. I understand that I can either add to the existing roof or create a second roof. In this model, I have it as a second roof. How would the sketch look if I wanted to attach it to the main roof?
thanks!
Profile Sweep over Roof Cricket [ 1 2 ]
Fri, Sep 7, 2012 at 12:47:31 PM
27
Roof Cricket in a sloping roof
Tue, Feb 14, 2006 at 5:59:03 PM
Roof cricket
Tue, Oct 21, 2008 at 1:47:04 PM
Roof Cricket
Mon, Jan 28, 2008 at 5:14:11 PM
Roof design problems
Fri, Jul 9, 2010 at 7:30:00 AM
12
Page generation time: 3.5669
