Forums >> Revit Building >> Technical Support >> Groups Edit Dialog Box missing
in r2010, when you edit a group you get a dialog box which is found on the HOME tab, see attached. in R2011, when I edit a group, there is no dialog box and I cant find a way to save and close a group i am editing. How do you save and close a group you are editing in r2011?
When I edit a group in 2011, I see the same dialog box that you posted. Perhaps you need to re-install.
Check this thread: http://www.revitcity.com/forums.php?action=viewthread&thread_id=20684
yes, go to that link, others with same problem: no solutions.
So - are you using dual screens? ...and did you install the update yet?
no dual screens. Win 7, lots of memory. r2011
REVIT RENDER QUALITY SETTINGS DIALOG BOX |
Thu, Dec 18, 2008 at 11:04:05 AM
Revit Dialog Box When Opening |
Thu, Feb 25, 2016 at 9:32:51 PM
Dialog Box won't appear if I give another window Focus while "Extending Changes" |
Fri, Aug 5, 2011 at 8:08:41 PM
Property Dialog Box Scroll Bar annoyance |
Tue, Nov 12, 2013 at 8:02:15 PM
Revit 2015 Unknown Pop up dialog box |
Tue, Jan 20, 2015 at 9:19:00 AM
Members: | 2104714 | Objects: | 23178 | Forum Posts: | 152306 | Job Listings: | 3 |
