49 Users Online (48 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> How to apply paint to walls/choose a colour?? (Revit Architecture)
Mon, Jun 21, 2010 at 10:01:04 PM | How to apply paint to walls/choose a colour?? (Revit Architecture)
ethand
Hi guys,
I'm still pretty new to revit architecture and have had to try teach myself. I've got most of it sussed, but i just cant figure out how to select a paint for walls/choose a colour for them. Most walls are fine to be grey/white, but there are some rooms in some of my projects that need feature walls to properly convey the design I'm doing.
Thanks in advance for your help!!
Tue, Jun 22, 2010 at 2:29:26 AM | How to apply paint to walls/choose a colour?? (Revit Architecture)
xzavoral
Select the wall press Right mouse button, at bottom you have properties for the selected object. Here you can Edit wall structure and in every layer of wall you can select material from Material library. Here you can also add your own materials.
Tue, Jun 22, 2010 at 10:21:43 AM | How to apply paint to walls/choose a colour?? (Revit Architecture)
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
To apply a paint color to a wall.
1. Open the materials dialog box and create a new material by duplicating another similar material.
2. Click the Rendered Appearance tab
3. Click the 'replace' button.
4. Select the paint color you want
5. On the graphics tab you can check the 'Use Rendered Appearance for Shading' or just pick a color from the big color rectangle button.
6. Close the materials dialog box
7. Now, edit the properties of the wall type
8. Click the skinny 'edit' button for the wall 'structure'.
9. Select the 'material' of the layer on the side of the wall you want painted
10. Pick your newly created material with paint
11. Ok, ok, ok, and that's pretty much it.
Once you create the material (step 5) you can also just use the REVIT 'Paint' tool to simply paint the face of the wall, or roof, or floor etc. with any material.
If you don't care about 'rendered appearance' and just want a 'shaded' paint you can pick a color off the Graphics tab of the Materials dialog box
Hope this helps.
Edited on: Tue, Jun 22, 2010 at 10:25:41 AM
Thu, Jun 2, 2016 at 12:40:39 AM | rendering problems
balaji93
dear sir,
         I need help from your side.when i finish my drawing. before rendering in the reality view .it will not seen clear.the what is my fault in my drawing.please kindly give me the your suggestion to get clarity and clear visual.attached my drawing below.to your reference.
i used REVIT 2016 version.
E-mail:bbalaji030@gmail.com
Thu, Jun 2, 2016 at 9:59:21 AM | How to apply paint to walls/choose a colour?? (Revit Architecture)
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Looks like you just need to create a new material and start by Duplicating a 'Paint' material which will have all the correct Assets that a paint material utilizes. See Image.
Mon, Nov 14, 2016 at 10:38:54 AM | How to apply paint to walls/choose a colour?? (Revit Architecture)
archigrafix
5 Stars: 4 Votes
If the purpose of the color adjustment is to show on a Revit view one can do it with just 2 clicks using Graphic Studio (free trial). Check here:
http://www.archigrafix.com/graphic-studio-2017.html
Plenty of color palettes included, and also possible to load more palettes more from colorlovers.com.
Marc Faber
BIM Solutions Developer
goto.archi | Oslo, Norway
Generic Model (How to Paint or apply materials)
Wed, Oct 9, 2013 at 12:09:41 PM
Render has glowing walls 2012
Thu, May 16, 2013 at 1:18:59 AM
Paint Walls
Fri, Dec 10, 2010 at 12:02:24 PM
How do you tell what finish has been applied with Paint?
Sat, Jan 26, 2013 at 5:14:42 AM
Help with finish tags
Wed, Nov 17, 2010 at 3:14:35 PM
Page generation time: 1.8711
