26 Users Online (25 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Workflow & Implementation >> API & Third Party Apps >> Matrix transforms
Mon, Jun 21, 2010 at 2:39:00 PM | Matrix transforms
paulh
Does anyone know a good source on the web to learn how to use matrix transforms?
I've been trying to figure out how to extend the length of a line by a given amount and just can't seem to pin it down. I'm also planning on doing so 3D stuff later on so I'd like to figure out how they work.
Mon, Jun 21, 2010 at 2:46:07 PM | Matrix transforms
3.5 Stars: 401 Votes
What is a "matrix transforms"?  Certainly not Revit terms.
Did you read the similar threads below? (Unlinked code matrix)
Mon, Jun 21, 2010 at 10:09:10 PM | WWHub
paulh
Quoting WWHub from 2010-06-21 14:46:07
No this has nothing to do with the threads below. Matrix transforms are for changing 3D vertices in 3D space.
Mon, Jun 21, 2010 at 11:54:14 PM | Matrix transforms
coreed
coreed Avatar
4 Stars: 16 Votes
if you are going to do stuff like that, you will probably have to interface through the API and some other programing langauge. why you want to do this in Revit???  i don't know. to each his own. check over at AUGI with the API guys. they can probably point you in the right direction.
hth
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Tue, Jun 22, 2010 at 9:55:31 AM | Matrix transforms
Perhaps you should look at this and talk to Mr. Spot:
http://blog.cadway.com.au/search?updated-min=2009-01-01T00%3A00%3A00%2B10%3A00&updated-max=2010-01-01T00%3A00%3A00%2B10%3A00&max-results=7
Is that what you are trying to do?
Tue, Jun 22, 2010 at 1:22:01 PM | coreed
paulh
Quoting coreed from 2010-06-21 23:54:14
hth
The Revit API already has a transform class for dealing with matrices. I just can't figure out how it works and want to learn. If you want to move or rotate objects via the API you have to know how it works. In my case I want to extend the length of a line (via the API) so I need to apply a transform to a vertex (hence matrix math is needed). I realize I can also do this with basic trig but since I want to write some apps that deal with 3D objects later on, I figured I might as well learn now.
Tue, Jun 22, 2010 at 1:32:54 PM | WWHub
paulh
Quoting WWHub from 2010-06-22 09:55:31
I didn't see anything that looked like API stuff on his blog. I'll send him a note but I think Mr.Spot is focused more on creating custom content instead of programming.
Tue, Jun 22, 2010 at 3:07:42 PM | Matrix transforms
coreed
coreed Avatar
4 Stars: 16 Votes
here are few Revit programing sites if you don't already have them
http://thebuildingcoder.typepad.com/
 http://cadappdev.blogspot.com/
http://revit-programmer.blogspot.com/
hth
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Matrix Schedules?
Mon, Mar 23, 2009 at 11:33:19 AM
Chicago Code Matrix
Mon, Aug 8, 2011 at 12:42:21 PM
Unlinked Code Matrix in Revit 2010?
Thu, May 13, 2010 at 2:12:40 PM
RST2010
Tue, Jun 2, 2009 at 5:29:50 PM
Rotation of materials in rendering
Thu, Aug 26, 2010 at 7:07:34 PM
Page generation time: 0.1885
