52 Users Online (50 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Need help with a Staggered/ Running bond pattern with angles
Mon, Jun 21, 2010 at 1:38:27 PM | Need help with a Staggered/ Running bond pattern with angles
rholtjr
Can anyone assist with getting this to be a staggered pattern?
Verticals and horizontals are where they need to be with the exception of shifting every other row of panels
 I am clueless at this point and have attached the *.pat file in hopes of assistance.
Thanks.
Mon, Jun 21, 2010 at 1:58:21 PM | Need help with a Staggered/ Running bond pattern with angles
Your question is not clear.  A pattern file has to describe enough of the pattern to do one complete pattern, then it starts again.  A standard running bond block or brick pattern is staggered one row to the next so it only describes two rows of units.  What is it that you want?  You should be able to do this using block as a model.
Tue, Jun 22, 2010 at 1:26:40 PM | Need help with a Staggered/ Running bond pattern with angles
rholtjr
Ok,
Using attached "8x16" block file as the pattern, I can only seem to get the horizontal lines  going how I need them. I am having trouble with the angled vertical lines.  I cannot get them to fall in between and on the ends of the dashed horizontal lines. Essentially i am trying to make a pattern of staggered parallagram panels. I have attached the example pat file, my pat file, and an image of where i am at the moment.
Help is greatly appreciated.
Tue, Jun 22, 2010 at 10:12:25 PM | Need help with a Staggered/ Running bond pattern with angles
hugh
3.5 Stars: 4 Votes
Could you post a dimensioned sketch of the pattern you want to achieve?
Here's the block pattern you posted skewed @ 60 degrees:
;%VERSION=3.0
;%UNITS=INCH
*SKEWED BLOCK-8X16,8 x 16 Block Running Bond, skewed 60deg
;%TYPE=MODEL
;        Pattern written by HatchKit v2.7 Hatch Pattern Editor
;        HatchKit v2.7 Hatch Pattern Editor(c) Cadro Pty Ltd.
;        www.hatchkit.com.au
;-Template=Block-8x16, 8 x 16 Block Running Bond
;-Source  =C:\Documents and Settings\Hugh\Desktop\78388_Block-8x16.pat
;-Date    =23/06/2010
;-Time    =1:03:06 PM
60,0,0,5.23760430726,6.92820323084,8.8046,-9.67060861255
60,15.625,0,5.23760430726,6.92820323084,8.8046,-9.67060861255
0,0,0,12.618802152,8,15.625,-0.375
0,4.4023,7.625,12.618802152,8,15.625,-0.375
Hugh Adamson
www.hatchkit.com.au
Wed, Jun 23, 2010 at 8:54:49 AM | Need help with a Staggered/ Running bond pattern with angles
rholtjr
Hi Hugh,
I have attached below the desired pattern I am trying for.
thanks
Wed, Jun 23, 2010 at 11:54:57 PM | Need help with a Staggered/ Running bond pattern with angles
hugh
3.5 Stars: 4 Votes
Try this based on 2' x 4' with 60 deg included angle and 1/2" gap, origin at lower left corner:
;%VERSION=3.0
;%UNITS=INCH
*24X48SKEWED60PANEL
;%TYPE=MODEL
;        HatchKit v2.7 Hatch Pattern Editor(c) Cadro Pty Ltd .
;-Template=NEW,
;-Date    =24/06/2010
;-Time    =2:41:57 PM
-119.960479335,24,41.569,42.44034332,10.6130334874,48,-49.1160485383
180,48,41.569,12,42.0692194,24,-0.5
60.039520665,24,0,42.44034332,10.6130334874,48,-49.1160485383
0,0,0,12,42.0692194,24,-0.5
The pattern will load to Revit at 1:1 scale (and took about 10 minutes to do and test).
Hugh Adamson
www.hatchkit.com.au
Custom Running Bond Brick Pattern
Fri, Aug 26, 2016 at 2:38:25 PM
4’ x 8’ running bond hatch.
Thu, May 8, 2008 at 7:02:50 AM
Staggered tile PAT file needed: 96" W x 21" H
Tue, May 20, 2014 at 3:19:02 PM
.pat file - running bond with angled tiles
Thu, Mar 30, 2017 at 6:28:09 PM
Vertical Reveals for Running Bond Pattern
Thu, Sep 3, 2009 at 8:20:46 AM
Page generation time: 0.4334
