156 Users Online (155 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Visibilty of Contour Lines
Mon, Jun 21, 2010 at 12:50:14 AM | Visibilty of Contour Lines
jberri
Contour lines on imported dwg survey are hidden by 3D topography while it is being constructed
making it very difficult to continue the process!
Is there a way to keep contour lines visible during this process?
Mon, Jun 21, 2010 at 7:31:07 AM | Visibilty of Contour Lines
It is far easier to create your topo automatically by importing 3D data, if the contour lines in the CAD drawing are set to the correct elevations.  HELP >  Creating a Toposurface from Imported 3D Data
Mon, Jun 21, 2010 at 9:32:47 AM | Visibilty of Contour Lines
TomDorner
4.5 Stars: 25 Votes
If the CAD file lines are not at the correct Z elevation, it is easier to change them in CAD then do as WWHub suggests.
Also in any view you can change the settings to wireframe so solids are not in your way.
Tom
Possible to place contour lines to toposurface instead of points?
Fri, Jun 1, 2018 at 2:57:53 PM
Hiding Contour Lines
Wed, Dec 16, 2020 at 10:00:04 PM
Revit 2017 - Topography contour lines visibility
Wed, May 5, 2021 at 1:55:54 PM
Contour Lines - not a surface
Wed, Mar 31, 2010 at 2:11:22 PM
Contour Lines Issue
Thu, Mar 27, 2008 at 11:35:30 AM
Page generation time: 2.3170
