73 Users Online (72 Members):
Forums >> Revit Building >> Technical Support >> Workset Release
I have taken over a job that has worksets. I am in the sole designer working from my home office hired to finish it. I am not familiar with worksets, but quickly found I cannot work on the file. Is there a way to release them without contacting original moldeler? This is such a small project I cant imagine why they ever used them but ... I just need to be able to work on the file.
Once worksets are disabled, you can no longer go back to stand alone files. It sounds like the previous user must not have released all worksets. The easiest and quickest fix is to open the file detached and create a new central file. That will release all the previous user's locks. Now, do a save-as which will create a new central and you can continue working. I suggest you read up o worksets, saving to central and creating local files.
Default Workset |
Sun, Sep 25, 2016 at 12:01:18 AM
Saving/unlinking a Workset Without Updating |
Wed, Oct 1, 2008 at 12:24:51 PM
Pipe visibility / workset problem |
Thu, Dec 22, 2011 at 9:02:36 AM
Any way to set up certain workset to be gray? |
Wed, Dec 8, 2010 at 3:23:00 PM
Hide a workset in a link |
Sat, Sep 20, 2008 at 10:04:45 AM
Members: | 2030530 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
