55 Users Online (54 Members):
Forums >> Revit Structure >> Technical Support >> How do I place interior lights and flooring materials??
15 Posts No Rating |
Hi there, i'm new to revit architecture, and want to know how to place lights in the interior of building? I just cant figure it out, and can't seem to find any other posts/sites on the net that address this. Also, I'd like to know how to change the floor materials, like if I want wooden or tiled flooring indoors? Thanks in advance for your help!
![gebber Avatar](user_avatar/50786.jpg)
![5 Stars: 4 Votes](/images/stars_5.gif) |
a light can be placed as a component. Be aware there are ceiling based and wall bassed lights wich can only be placed on a ceiling or a wall. It might be a good idea to check the revit help to make you understand how revit works. to change the flooring material 1 select the floor, 2 click edit type in your properties dialog 3 click edit structure here you can change the materials and the structure of your floor
ok thanks a heap! Can the ceiling mounted lights be mounted to the soffit (i.e the underside of the floor above it) or must I create a ceiling to place them? and which view do you have to be in to place a ceiling mounted light? cheers
Render exterior view with artificial lights - how to make interior glow? |
Sun, Mar 11, 2012 at 12:45:28 PM
how to apply flooring materials |
Sat, Sep 2, 2006 at 2:49:34 PM
Exterior night rendering with interior lights on? R16 |
Wed, Aug 3, 2016 at 1:23:36 PM
rotating materials |
Wed, Dec 26, 2007 at 10:45:40 AM
interior rendering, lights won't come on |
Thu, Apr 25, 2013 at 10:42:56 AM
Members: | 2022361 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
