55 Users Online (54 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Hatch Pattern Scale Question
Wed, Jun 16, 2010 at 3:00:10 PM | Hatch Pattern Scale Question
Xaquin
I created this hatch pattern:
*CMU XXXX,  CMU;%TYPE=DRAFTING0,            0,             0,             0,             8.00,            0,             0.375,          0,             8.0
For some reason, when I import it into revit it's about 13'-0" from line to line as opposed to 8".  I have no idea how to scale it so that it reppresents the 7 5/8" CMU and the typical 3/8" mortar that it should import as.  Am I doing something wrong?
Any help is greatly appreciated
Wed, Jun 16, 2010 at 3:16:41 PM | Hatch Pattern Scale Question
TKennedy
4 Stars: 7 Votes
I'm thinking that you need to make it a model pattern, not a drafting pattern.
Wed, Jun 16, 2010 at 3:25:53 PM | Hatch Pattern Scale Question
Xaquin
I tried that, but when I went to import it, it kept saying 'No Drafting Pattern Found' or something similar.  It wouldn't let me import a model pattern.
Wed, Jun 16, 2010 at 4:22:24 PM | Hatch Pattern Scale Question
TKennedy
4 Stars: 7 Votes
I'm not familiar enough with hatch patter creation to tell you exactly why it's giving you an error, but I do know you need a model pattern. Right now it's making your lines 8 paper inches apart, which is why they look so big. Check your Help, and google revit hatch patters.
Wed, Jun 16, 2010 at 9:35:07 PM | Hatch Pattern Scale Question
hugh
3.5 Stars: 4 Votes
There is a point in the import process where you select whether you wish to import MODEL or DRAFTING. Change
*CMU XXXX,  CMU
;%TYPE=DRAFTING
to
*CMU XXXX,  CMU
;%TYPE=MODEL
in the text file, select Model during import and you should be there.
Hugh Adamson
www.hatchkit.com.au
Thu, Jun 17, 2010 at 6:46:55 AM | Hatch Pattern Scale Question
bryanmmiller
Is it exactly 12.5 feet from line to line?
Thu, Jun 17, 2010 at 8:31:12 AM | Hatch Pattern Scale Question
3.5 Stars: 395 Votes
You might try adding this line to your file:
;%UNITS=INCH
hatch scale?
Sun, May 10, 2009 at 3:33:47 PM
Exporting hatch pattern
Thu, Sep 18, 2014 at 6:27:35 PM
hatch pattern scale in my family doesn't transfer to my project
Wed, Jan 22, 2014 at 11:10:08 AM
hatch pattern not printing
Mon, May 8, 2017 at 12:56:51 PM
Hatch pattern
Tue, Jan 13, 2009 at 10:23:47 AM
Page generation time: 0.6177
