73 Users Online (72 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Turn off section references that occur in the background of an elevation
Tue, Jun 15, 2010 at 5:25:22 PM | Turn off section references that occur in the background of an elevation
chowlowhammond
I've got a number of elevations where the far clipping range goes WAY back to show the portions of the building that occur back there... We've all encountered this...
The problem is: by setting the "Far Clip Offset" so far back - it picks up a whole bunch of wall & detail section references which are NOT relevant to my elevation.  This means that I have to double check every single section reference that shows up in my elevations & manually hide the ones that are incorrect... Babysitting things in Revit is not fun... It always makes for errors & inconsistencies (kind of like AutoCAD).
Is there a way to define how far back your elevation will display any adjacent section references?  Or am I stuck doing this manually?
If this doesn't make sense, I will show a few pictures.
Wed, Jun 16, 2010 at 6:34:56 AM | Turn off section references that occur in the background of an elevation
3.5 Stars: 401 Votes
I think you are stuck.
... and you do know about using your window and funnel filter to select multiple section references to hide in view?
Edited on: Wed, Jun 16, 2010 at 7:55:40 AM
Wed, Jun 16, 2010 at 2:10:12 PM | Turn off section references that occur in the background of an elevation
Bimman
Bimman Avatar
1 Stars: 2 Votes
i think you set to hide in views courser than a certain scale factor. just set that to a low scale and it would not show up. say set it to 1/8" and if section was at 1" then the marker would not show up becuae it is hidden.
PWD
Section References Disappearing
Sun, Sep 13, 2009 at 11:40:02 AM
Topography and hatching in section / elevation
Sat, Sep 27, 2008 at 7:55:41 PM
Revit 2011 Multiple Interior Elevation References
Wed, Oct 26, 2011 at 9:01:48 AM
Thu, Jan 8, 2009 at 2:56:42 PM
Section drawing references
Fri, Jun 21, 2013 at 11:46:25 AM
Page generation time: 0.7838
