70 Users Online (67 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> 2nd flr walls not lining up with first floor walls
Tue, Jun 15, 2010 at 2:51:17 PM | 2nd flr walls not lining up with first floor walls
bellgroup
I had the walls all lined up and then went and moved the 1st flr. walls, now when I try to draw the second floor walls on top of the 1st flr.. walls below they are being placed offset of the first flr. on the elevation. the funny thing is that as I'm drawing them in on the 2nd flr.  floor plan  I have the 1st flr. as a underlay and they appear to be stacking up correctly.
Tue, Jun 15, 2010 at 4:58:44 PM | 2nd flr walls not lining up with first floor walls
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
Try using the align tool and make sure that you are using the correct line to start with. I generally align wood walls by outside core, this is the typical construction technique. Also make good use of the grid and lock your walls onto it. This will help prevent them from moving by mistake.
Wed, Jun 16, 2010 at 2:20:43 PM | 2nd flr walls not lining up with first floor walls
Bimman
Bimman Avatar
1 Stars: 2 Votes
i would also suggest once you align them you lock them so they stay together.  that way if you move your second floor both floors will move together and you do not have to move or realign the second floor walls to match the first floor walls.
PWD
CUT PLANE IN wINDOW
Tue, Jan 12, 2010 at 4:30:41 PM
WINDOW CUT PLANE IN 2010
Thu, Jan 7, 2010 at 10:38:28 AM
Walls are greyed out
Fri, Dec 14, 2012 at 6:55:18 AM
Schedule walls by floor
Tue, Jan 2, 2007 at 4:13:31 PM
Relative Revit Levels.
Mon, Sep 15, 2014 at 9:58:20 PM
Page generation time: 1.2008
