62 Users Online (61 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Guidance on parameters
Tue, Jun 15, 2010 at 6:40:40 AM | Guidance on parameters
archie456
3 Stars: 1 Votes
Hi,
I'm currently setting up my custom door and window tags, and I would appriciate some advice on where to store inforamtion about the project.
Essentally, my project is building number 8 or a larger project. I would like all references, door marks, window marks, room marks etc to be prefixed by the building number.
Do my door mark would be:
8/G-015.
Which would be building 8, G for Ground Floor and door 15.
Where is the best way of storing the building number - I guess this would be a shared parameter? But what catagory would I use?
Also, whats the best way of telling Revit that all the ground floor doors have G in the number and first floor doors have F - without manually writing this?
I guess at a simple level I could do all of this manually, but it would be good for Revit to add the some bits automatically.
Cheers!
Tue, Jun 15, 2010 at 6:49:24 AM | Guidance on parameters
3.5 Stars: 396 Votes
Category ?  Text?
Both the building number and floor number would have to be manually entered if used in a tag.  A door location by floor can be read in a schedule.
BTW - Sice we have no text string manipulation available in Revit, the additional characters "/" "-" would have to be fixed in place in the tag.  In addition, I don't believe you can have the preceeding 0 in the door number.
Tue, Jun 15, 2010 at 7:48:38 AM | Guidance on parameters
archie456
3 Stars: 1 Votes
thanks for your reply - manual it is.
Mystery parameters - shared?
Tue, Nov 10, 2015 at 7:06:20 AM
Convert files and layers to DWG
Sun, Feb 26, 2012 at 11:17:55 AM
Titleblock Parameters [ 1 2 ]
Thu, Mar 13, 2014 at 4:57:53 PM
17
Instance Parameters in titleblock not linking
Wed, Dec 28, 2011 at 10:31:23 AM
12
Shared or Project Parameters?
Tue, Jan 19, 2010 at 7:01:11 PM
Page generation time: 0.3483
