27 Users Online (26 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> How to make this curved pipe?
Mon, Jun 14, 2010 at 8:19:33 PM | How to make this curved pipe?
radditok
I want to build this building(picture in attachment) in revit 2009. But I got  a problem. I couldn't make the curved pipe (in the picture that I attached, the red line). I have tried making a mass and then create mullion, but it couldn't happen. somebody could help me?
thanks before
Tue, Jun 15, 2010 at 6:01:03 AM | How to make this curved pipe?
4 Stars: 201 Votes
I no longer use the 2009 version but did you try with a In-Place> Solid Sweep > Pick Path"?
Tue, Jun 15, 2010 at 11:43:26 PM | How to make this curved pipe?
radditok
I've tried it, but the path should be perpendicular. And it can't be curved sloping. Could you help me step by step?
Wed, Jun 16, 2010 at 1:59:18 PM | How to make this curved pipe?
Bimman
Bimman Avatar
1 Stars: 2 Votes
use model lines to create your path. then when you make your sweep use pick path rather than sketch path. pick your model lines.  set reference planes before hand that you draw your model lines in that way they can slope, curve and what ever else you draw in the refernce plane.  i draw handrail pipes all the time with this method and they slope at the same angle of the stairs and then curve at the landings and head down the next set of stairs.
PWD
Tue, Jun 29, 2010 at 2:58:13 AM | How to make this curved pipe?
radditok
thanks, i did it.. but i tried to use curtain system,,
bravo revit
Tue, Jun 29, 2010 at 11:49:19 AM | How to make this curved pipe?
NkatOmg2
NkatOmg2 Avatar
4 Stars: 1 Votes
Hey radditok, congratulations.
Can you post a picture of it? I want to see.
 I use Autodesk Revit Structure 2011
 My songs: http://nkat.newgrounds.com
Trim HSS Round pipe into another HSS Round pipe
Tue, Apr 3, 2012 at 4:39:45 AM
DOWN PIPE !!
Thu, Apr 7, 2005 at 4:28:50 AM
Curved Pipe
Thu, Apr 23, 2020 at 5:10:36 PM
How to get pipe fittings to appear as simple pipe lines?
Thu, Mar 20, 2014 at 4:40:08 PM
12
PIPE COLOR
Thu, Apr 1, 2010 at 10:43:51 AM
Page generation time: 2.2288
