90 Users Online (89 Members):
Forums >> Revit Building >> Technical Support >> How do i create Formwork for walls and slab using revit architecture.?
1 Posts No Rating |
anyone? im stuck on this...basically i need the standard offset for the each 1200mm x X 900mm, let say i had a wall that lenght 6m..so how do i create this wall divide each into each panel, then the balance remain in what so ever, in addition i need it to automatically key in also the text of the sizes..? (im trying to use the curtain wall sytem, but i dunno if its appropriate). the same problem with the slab also, but slab i had not figure it out how do i do this...Anyone can helo? many thanks in advance.
I think i create that by "Curtain Walls"...
i downloaded a revit extension pack for 2010 architecture, that had a framing creator in it. you layout the wall and you can specify headers, jacks, and king stud as weel as framing spacing. works petty nice.
----------------------------------- PWD |
Showing walls from the bottom of slab |
Tue, Feb 9, 2010 at 10:40:40 AM
How to compute formwork |
Sat, Mar 17, 2012 at 3:00:07 PM
Revit Architecture / Revit Structure Coordination Issues |
Fri, May 7, 2010 at 10:19:04 AM
How do I get a slab system family into my project? |
Tue, Mar 17, 2009 at 12:52:42 PM
Create Void as Slab Edge |
Sun, Oct 2, 2016 at 11:39:37 PM
Members: | 2057441 | Objects: | 23074 | Forum Posts: | 152250 | Job Listings: | 3 |
