79 Users Online (77 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> General Discussion >> Revit Project Management >> i have som elements (roofs ,masses,...)above the cut plane and i want to see the
Sat, Jun 12, 2010 at 10:28:27 AM | i have som elements (roofs ,masses,...)above the cut plane and i want to see the
mhbn4
2.5 Stars: 4 Votes
i have som elements (roofs ,masses,...)above the cut plane and i want to see them in dash line style or other line styles.i chenged my view range primary range but i couldent do it .help that how can i du dath not in plan region way or ceiling reflected plan.sample progect is atached
Wed, Jun 16, 2010 at 9:24:46 AM | i have som elements (roofs ,masses,...)above the cut plane and i want to see the
Fnunez
5 Stars: 2 Votes
I am not 100% sure what you are trying to accomplish. But if you wish to make your drawing look like the image attached,
This link should help: http://screencast.com/t/YTM2NTc2NWU
Workaround steps shown in video (no audio):
Step 1 - In view properties for Level 1 set Underlay to Level 2.
Step 2 - Select the element you wish to show dashed and override its projection line settings
Void Masses
Fri, Oct 3, 2008 at 4:11:06 PM
joining roofs
Mon, Jan 9, 2006 at 1:20:09 PM
Join 2 roofs, like joining 2 walls
Wed, Nov 10, 2010 at 7:23:34 AM
Cut Plane display issue
Tue, Oct 11, 2011 at 12:48:42 PM
Materials on masses are being applied to all my masses...HELP!?
Sat, Mar 14, 2009 at 1:58:58 PM
Page generation time: 1.5782
