84 Users Online (82 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Tips & Tricks >> Revit 2011 products crash when attempting to replace material render appearance
Fri, Jun 11, 2010 at 12:32:38 PM | Revit 2011 products crash when attempting to replace material render appearance
4 Stars: 202 Votes
Published date: 2010-Jun-09
Applies to:
Autodesk® Revit® Architecture 2011
Autodesk® Revit® MEP 2011Autodesk®
Revit® Structure 2011
Issue
When you attempt to replace a Revit 2011 material render appearance the application crashes with an Autodesk Revit has stopped working error.
Solution
The crash is related to the render appearance library previews.  The following process should prevent the crash from occuring:
  1. Manage > Materials.
  2. Render Appearance tab.
  3. Next to preview image, click on the down arrow icon to display shape options and render quality options.
  4. Set quality > Rendered – Draft Quality.
  5. Click OK to close Materials dialog.
  6. Manage > Materials > Render Appearance tab > Replace…
Revit should not crash after the quality is set > Rendered – Draft Quality.  After changing the quality to draft and verifying the render appearance library does not crash, the preview quality can typically be set back to medium or high quality without subsequent crashes.
Edited on: Fri, Jun 11, 2010 at 12:34:38 PM
Tue, Jan 11, 2011 at 11:05:47 AM | Revit 2011 products crash when attempting to replace material render appearance
keyaggie
I have tried this solution twice and Revit stops when I hit OK, after following all the steps.
I am dong this in a brand new family (2011).
any more ideas??
Thanks
Thu, Mar 10, 2011 at 1:02:28 PM | Revit 2011 products crash when attempting to replace material render appearance
A1Gaudi
5 Stars: 5 Votes
I had same problem and could not modify materials, it crashed every time I hit ok.
This helped:http://revitclinic.typepad.com/my_weblog/rendering/
in my case I had to uninstall the Wacom tablet drivers (solution1)
Tue, Jul 5, 2011 at 10:44:17 AM | Revit 2011 products crash when attempting to replace material render appearance
Izzy27
My problem was solved with a simple issue:
When you're in the 'Render Appearance Tab, make sure you also check the 'Relief Pattern' Box. This will definitely solve the issue. So I say....follow Typhoons same instructions but after setting the quality to 'Draft', make sure to check the 'Relief Pattern Box'.
Thu, Jul 7, 2011 at 9:19:30 AM | Revit 2011 products crash when attempting to replace material render appearance
apetitdeux
for your information, it seems this concern is linked to a trouble with wacom pen tablet drivers
you may also disable the driver while using revit, which sometimes solves the problem
Thu, Jul 7, 2011 at 9:40:55 AM | Revit 2011 products crash when attempting to replace material render appearance
Izzy27
Wow really? That makes so much sense, because I have an Intuos 4 tablet. No wonder. Thanks for the info....helps alot
Fri, Oct 14, 2011 at 11:23:27 AM | Revit 2011 products crash when attempting to replace material render appearance
Keamosaaby
The Autodersk site has the fix:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15255349&linkID=9243099
Good Luck
Revit 2011 Custom Material Crash (Video)
Tue, Jun 7, 2011 at 1:23:22 PM
Adding new render material
Wed, Nov 2, 2011 at 10:39:46 PM
Revit Crashes. Help please.
Wed, Oct 6, 2010 at 11:02:05 AM
Render Appearance Library - Reloading
Wed, Mar 18, 2009 at 1:04:32 PM
Material Appearance in Revit 2019
Tue, Apr 28, 2020 at 10:44:52 AM
Page generation time: 1.9195
