69 Users Online (68 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Systems >> Technical Support >> Multiple Ceiling heights
Fri, Jun 11, 2010 at 8:42:50 AM | Multiple Ceiling heights
JosephTurc06
Ok...I have a buidling where a few rooms have a ceiling elevation changes. For ease of explaniation, picture a 20'x20' room with a ceiling height of 10'. Then there is a 3'x20' strip along the exterior wall that goes to a 12' elevation. The change in elevation happens with a 90degree rise (no slops in the ceiling). There is a 3'10" plenum above.
Here's the question. How are people setting up spaces/plenums where the top or bottom plane has two different elevations?
Fri, Jun 11, 2010 at 12:55:26 PM | Multiple Ceiling heights
buffys
Create two separate ceilings at the heights that you want.  Then make a "wall" with gyp or whatever on one side, go to a section view and pull the wall up to your lower ceiling.
Fri, Jun 11, 2010 at 1:18:53 PM | Multiple Ceiling heights
JosephTurc06
The arch. has it modeled correctly. I am trying to figure out how to get a space (in Revit MEP) to have that step in it. If I apply a space to these rooms it treats it as though it has a flat ceiling and dosen't account the for step up in the ceiling. This is a problem for my spaces as well as my plenums.
Fri, Jun 11, 2010 at 1:30:55 PM | Multiple Ceiling heights
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
check to see if the cripple wall and the ceiling are set with room bounding, maybe that is it
Ceiling heights in schedules
Thu, May 26, 2005 at 9:26:42 PM
Tagging multpile ceiling heights in the same plan
Tue, Jan 8, 2008 at 4:46:30 PM
Apartment Groups - Ceiling heights
Mon, Jul 21, 2014 at 11:11:51 AM
Ceiling height column problem in schedules
Fri, Dec 7, 2007 at 10:23:16 AM
Ceiling Plan View Range
Sat, Feb 23, 2008 at 9:22:53 PM
Page generation time: 0.4034
