128 Users Online (126 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> General Discussion >> Revit Project Management >> I want to know how to work with work set
Fri, Jun 11, 2010 at 6:52:18 AM | I want to know how to work with work set
nishakal
Hi,
I want to know how to work with workset, and how we can assign permission to different user I try with in my office. I am Abel to create Work set and work on the Project With different user. the main problem. is i can not restrict any user for any Edit or change.
Fri, Jun 11, 2010 at 7:08:55 AM | I want to know how to work with work set
You can not really assign worksets, that is not their purpose.  However, if one user has a worset "checked out" other users will no be able to work in that workset.
Some people have tried to use this to lock portions of the file but I don't believe they have found it to work very well.  I believe the sanwer to you needs is to teach discipline to your users.  Revit is a big change from cad because a change in one place can and does change many other areas.  This fact has to be learned and you need to find a way of working using this rather than fighting it.
Tue, Jun 15, 2010 at 6:54:48 AM | I want to know how to work with work set
nishakal
thanks for your replay
If you know about work set in detail then will you please send me complete step to manage work set
Tue, Jun 15, 2010 at 7:11:11 AM | I want to know how to work with work set
There are books available as well as documents directly from AutoDESK on using worksets.  I suggest you start with those.
Mysterious removal of ownship of certain work set
Mon, Aug 8, 2011 at 3:14:48 PM
cant set work plane
Fri, May 11, 2018 at 1:06:35 AM
Set roof or soffit on work plane?
Mon, Dec 2, 2013 at 12:57:49 PM
14
ABOUT SET UP WORK PLANE
Thu, Aug 5, 2010 at 9:30:56 AM
REVIT 2011 - set view to work place?
Wed, Nov 30, 2011 at 11:59:49 AM
Page generation time: 4.6650
