Forums >> Revit Building >> Technical Support >> Element's internal join data is corrupt
30 Posts No Rating |
I tried to change the level of a wall and I go this message- Element's internal join data is corrupt. Any ideas what this means? I am using Revit 2011.
4 Posts No Rating |
I am getting the same message when i try to delete some walls. Help anyone?
4 Posts No Rating |
We audited the file and that seemed to work.
2 Posts No Rating |
Just had the same issue. When I got the error, I expanded the error and it showed me the element which was causing the issue. In my case it was a wall. I copied the element's ID and then did a search by that ID number. It returned me the wall causing the issue. I cut it (ctrl x), did my changes to the slab and pasted the wall back into the same place. I then had to re-attach it to my slab. problem solved!
2021
I have the same issue. I audited the file and still get the message. I looked for the other element like dhenhoeffer and the wall is parallel to the wall I am trying to move. I tried to unjoin them but that didn't work. I can't even delete the wall to draw a new one. Help!
Which wall is it that you can't delete? Try deleting both.
Are you sure it is the wall you see or is there another one? Could be higher / lower / hidden.
Just guesses on my part.
Oh... and phases?
Edited on: Mon, Jan 10, 2022 at 9:59:59 AM
Thanks WWhub, It was a phase issue, didn't think phases would mess it up. I changed the phase of the parallel wall and then was able to move the other wall. Then changed the phase back on the parallel wall.
