155 Users Online (154 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Tilt Building Bearing Pockets
Tue, Jun 8, 2010 at 9:17:15 AM | Tilt Building Bearing Pockets
Lenhoksin
We do a lot of Tilt buildings at our company. I have been searching for information on creating bearing pockets for joist and joist girders in our panels and can't find anything in Revit or any forums. Bearing pockets aren't unusual.  I've tried creating my own with no luck.  Does any body have anything to share?  Tilt jobs typicaly will have hundreds of these pockets.
Tue, Jun 8, 2010 at 1:55:07 PM | Tilt Building Bearing Pockets
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
I am assuming that you are talking about tilt-up concrete walls. A bearing pocket could be formed in such a wall much as it would be the same way it is constructed, use the component in place and model a void form probably a square to create a notch in the concrete. Hope this helps.
Tue, Jun 8, 2010 at 2:51:41 PM | Tilt Building Bearing Pockets
Lenhoksin
I have tried using voids but the problem I run into is that I can't copy them from panel to panel.  I was hoping to avoid having to recreate the void 60 times.
Tilt Building roofs
Thu, Jun 10, 2010 at 9:47:38 AM
Adjusting the building workplane so that it orients to site bearing.
Tue, Aug 5, 2014 at 7:23:49 AM
Beam and joist pockets
Wed, Dec 22, 2010 at 9:27:48 AM
Using Revit for Tilt-Up Design-Build purposes
Wed, Jan 9, 2008 at 4:04:29 PM
Tilt-Up Warehouse
Fri, Nov 1, 2013 at 10:48:00 AM
Page generation time: 0.4854
