65 Users Online (63 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Dimensions
Mon, Oct 3, 2005 at 10:10:10 AM | Dimensions
DHerbert
DHerbert Avatar
I have laid-out some dimensions on Level 1 that I would like to use on my Level 2 view in the same scope box. Is this possible? Do I have to re-dimension the Level 2 plan? Thank you for you help.
Mon, Oct 3, 2005 at 11:50:16 AM | RE: Dimensions
Rythmick
5 Stars: 2 Votes
Copy and in your other view "paste aligned" / "same place"
Mon, Oct 3, 2005 at 4:38:53 PM | RE: Dimensions
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
I think you'd find you would need to paste aligned by current view... same place will put them right back in the original view....
Mon, Oct 3, 2005 at 4:45:00 PM | RE: Dimensions
DHerbert
DHerbert Avatar
Success. Thank you both for your help.
Mon, Oct 3, 2005 at 6:02:14 PM | RE:
Rythmick
5 Stars: 2 Votes
Quoting Mr Spot - 2005-10-03 16:38:52
"I think you'd find you would need to paste aligned by current view... same place will put them right back in the original view...."
Same Place works fine for me!
EQ Display in dimensions Revit 2009
Tue, Mar 23, 2010 at 3:28:37 PM
Isometric Dimensions in Drafting Views (details)
Fri, Sep 28, 2012 at 3:13:09 PM
Changing Dimensions
Mon, Feb 7, 2011 at 9:02:53 AM
Disappearing Dimensions
Mon, Aug 19, 2013 at 12:33:57 PM
temporary dimensions disappeared
Wed, Apr 25, 2012 at 10:37:52 AM
Page generation time: 0.2407
