Forums >> Revit Building >> Technical Support >> Step by step of exporting revit model to 3dsmax for render (Vray)?
Hi! I have a RAC2010 64-bit and i want to render it to 3dsmax2010 64-bit, a simple interior room would be nice to begin with as an example, I already searched and tried earlier steps of it like opening the interior scene view ready for render and export it to FBX file->open 3dsmax-> import..and i'm stuck i dont know the next step for it. PS: I already installed Vray for its method of rendering.... I would understand any explanation on this thread or simply links that helps on this query is highly appeciated Thank you in advance!
After importing and FBX file from revit i dont know what would be next begining from selecting presets right after importing...
Revit and Autodesk FBX are not Vray compatible. Once you import the FBX you must change all the materials and erase the photometric lighting and replace it with vray lighting.
"Revit and Autodesk FBX are not Vray compatible." Hmmmm....alabaster, depends on the version, VRay 1.5 SP4 is now compatible with Revit & Autodesk FBX files.
Whatchu talkin bout Ernesto!?!?! It uses MR materials and photometric lighting? I abandoned Vray a while ago. you got a trial of SP4?
BTW i have a registered V-Ray Adv 1.50.SP4 installed.. What should i select next? Autodesk Architectural (Revit) or Autodesk Media & Entertainment? Please tell me what's the difference between the two options and what is preferable to select, Please see image below. Thank you for any help you can suggest...
I already tried the two options but i'm still clueless about which to choose, please guide me until it renders to vray.. I'll just keep practicing at the moment waiting for a helpful reply Thanks “Learning never exhausts the mind.” — Leonardo Da Vinci , erland73 :D
" Whatchu talkin bout Ernesto!?!?! It uses MR materials and photometric lighting? I abandoned Vray a while ago. you got a trial of SP4? " alabaster, the first image was render in Revit (0:09:36 Medium 300 DPI), the second one is the .fbx file imported into Max 2011 and rendered with VRay 1.5 SP4 (0:01:30 Medium). I just rendered the model (I mean, I didn't apply new materials on it). Well, as you can see the only material that is not compatible is the glass, but in anyway........and yes, the lighting fixtures imported, work as well....
Edited on: Mon, Jun 7, 2010 at 11:37:48 PM
Hope you're not arguing..:p Sir Ernesto , can you please tell the process you did from revit to max, i really wana learn it, just enumerate it the simplest way you could and i'll be the one to explore, i just wanna know the basic like you just did in the picture... Clever as always my friend..
mrbeandiesel, First i would suggest downloading the latest FBX plugin, check your webupdates button on the import dialogue.
mrbeandiesel, about the fbx thing, maybe this could be useful for you.....
Edited on: Tue, Jun 8, 2010 at 9:10:01 PM
are you using vray alot ernesto? i just got sp4 and started messing with it. i havint used vray in a few years so i'm having to relearn it
"are you using vray alot ernesto?" Not really,Matt....depends on the client. I'm trying with Fryrender nowadays. Easier to set up....
Edited on: Wed, Jun 9, 2010 at 8:11:19 PM
yeah i tried just opening a revit fbx and hitting render on vray, looks kinda wierd
Yeah, it seems that although it preserves the materials from Revit, it loses some settings (brightness,etc.)
