71 Users Online (70 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Tips & Tricks >> When you attempt to use the Navisworks exporter in Revit, a “localization” error
Fri, Jun 4, 2010 at 12:38:52 PM | When you attempt to use the Navisworks exporter in Revit, a “localization” error
4 Stars: 203 Votes
Published date: 2010-Jun-03ID: TS15175458
Applies to:
Autodesk® Navisworks® Manage 2011
Autodesk® Navisworks® Manage 2010
Autodesk® NavisWorks® Manage 2009
Autodesk® Navisworks® Review 2010
Autodesk® NavisWorks® Review 2009
Autodesk® Navisworks® Simulate 2011
Autodesk® Navisworks® Simulate 2010
Autodesk® NavisWorks® Simulate 2009
Autodesk® Revit® Architecture 2011
Autodesk® Revit® Architecture 2010
Autodesk® Revit® MEP 2011
Autodesk® Revit® MEP 2010
Issue
When you attempt to access the Navisworks exporter from the Revit > Add-ins > External Tools menu option, a “localization” error displays and the export does not occur.
Solution
Occasionally, the Revit exporter does not initialize properly during installation. A repair of the exporter should correct the issue.
Repair the Exporters:
  1. Close Navisworks and Revit.
  2. Click Start > Settings > Control Panel.
  3. Click "Add or Remove Programs".
  4. Select the Autodesk Navisworks Manage **Your Version** Exporter Plug-ins option and click "Change/Remove".
  5. Click "Repair or Reinstall".
  6. Follow the prompts to complete the process.
  7. Test the exporter.
If this process does not correct the issue, you can manually uninstall/reinstall the Revit plugin. This process may require your installation disk or downloaded installer files.
  5. Click "Add or Remove" features.
  6. Scroll down the list and locate the Revit plugin for your version of Revit.
  7. UNCHECK the Revit plugin.
  8. Click "Next" and follow the prompts and uninstall the Revit exporter.
  9. Close out of the window.
  10. Select the Autodesk Navisworks Manage **Your Version** Exporter Plug-ins option and click "Change/Remove".
  11. Click "Add or Remove" features.
  12. Scroll down the list and locate the Revit plugin for your version of Revit.
  13. CHECK the Revit plugin. You may need your installation disk.
  14. Click "Next" and follow the prompts and install the Revit exporter.
  15. Retest the exporter.
If this does not work, you can remove your Revit.ini file and uninstall/reinstall the exporters.
  2. Navigate to c:\Program Files\Revit **Product**\Program\
  3. Rename your Revit.ini file (this will remove your Revit desktop settings).
  4. Start Revit.
  5. Close Revit (this will rebuild your ini file).
  6. Click Start > Settings > Control Panel.
  7. Click "Add or Remove Programs".
  8. Select the Autodesk Navisworks Manage **Your Version** Exporter Plug-ins option and click "Add or Remove Features".
  9. Scroll down the list and locate the Revit plugin.
  10. UNCHECK the Revit plugin.
  11. Click "Next" and follow the prompts and uninstall the Revit exporter.
  12. Close the window.
  13. Select the Autodesk Navisworks Manage **Your Version** Exporter Plug-ins option and click "Change/Remove".
  14. Click "Add or Remove" features.
  15. Scroll down the list and locate the Revit plugin.
  16. CHECK the Revit plugin. You may need your installation disk.
  17. Click "Next" and follow the prompts to install the Revit exporter.
  18. Test the Navisworks exporter.
Here, the original post from Autodesk: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15175458&linkID=9243099&CMP=OTC-RSSSUP01
Edited on: Fri, Jun 4, 2010 at 12:40:38 PM
Thu, May 17, 2012 at 1:11:47 PM | When you attempt to use the Navisworks exporter in Revit, a “localization” error
Allison
I am in Revit Architecture 2011 and cannot even find "tools", "add-ins", or "external tools".  Am I missing a toolbar? So confused...
Thu, May 17, 2012 at 1:19:26 PM | When you attempt to use the Navisworks exporter in Revit, a “localization” error
IF YOU HAVE NO INSTALLED ADD-ONS, THEN YOU WILL NOT HAVE THE TOO ON YOUR TOOLBAR.
SORRY FOR CAPS - WORKING
Fri, May 18, 2012 at 6:54:00 AM | When you attempt to use the Navisworks exporter in Revit, a “localization” error
Allison
Thanks! I installed the add-ons tab, and now have the 'external tools' button.  Still not seeing anything that offers to 'export' or anything about Navisworks.  Only thing I am able to click is "revit extensions manager'.
NavisWorks Exporter
Mon, Mar 28, 2011 at 3:40:01 PM
Navisworks Exporter 2014
Thu, May 23, 2013 at 4:07:44 PM
2016 export Revit files to Navisworks without using Navisworks Exporter.
Thu, Apr 21, 2016 at 4:53:16 PM
Revit to Navisworks - No exporter in 2010
Thu, Aug 6, 2009 at 9:04:12 PM
In Revit, the Navisworks File Exporter is grayed out on the ribbon menu
Fri, Jun 4, 2010 at 12:42:23 PM
Page generation time: 3.6172
