66 Users Online (63 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Systems >> Technical Support >> printing revision clouds in color
Fri, Jun 4, 2010 at 10:54:05 AM | printing revision clouds in color
joshb
Does anyone know if there is a way to have my drawings to print in black and white but to keep the red color of the revision clouds to show red when i print?
 Thanks!
Fri, Jun 4, 2010 at 1:08:59 PM | printing revision clouds in color
bryanmmiller
You should be able to go to "Object Styles" and under the "Annotation Objects" tab change the Revision Clouds to be any color or line weight you desire.
Fri, Jun 4, 2010 at 1:35:00 PM | printing revision clouds in color
joshb
Yes, and that's what we have done but we also have other colors in place for different types of pipes, like CW, HW and HWR. So, when I print I only want the color of the revision clouds to show up and the rest to be black lines.
Fri, Jun 4, 2010 at 1:43:47 PM | printing revision clouds in color
bryanmmiller
Maybe, you could create a View Template for keeping the other settings colored the way you want and create another View Template with everything black lines except the Revision Clouds (Red).  With the view template you could switch back and forth for printing.
Revision Clouds
Tue, Dec 18, 2007 at 10:52:45 AM
Revision clouds - off on one sheet but not on other sheets - is this possible?
Fri, Mar 16, 2012 at 9:13:40 PM
shading revision clouds Revit 2017
Wed, Feb 28, 2018 at 2:56:29 PM
Revit clouds
Tue, Jul 29, 2014 at 10:43:13 AM
Revsions & Revision Clouds
Wed, Feb 20, 2013 at 1:32:14 PM
Page generation time: 0.7630
