134 Users Online (133 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> importing autocad drawings
Mon, Oct 3, 2005 at 6:47:15 AM | importing autocad drawings
Nathan
4.5 Stars: 3 Votes
When I try to import drawings from autocad into revit using the Import/Link command the drawings are displayed to a ridiculous scale. How can the import settings be changed so that they fit the scale in revit. thanks nathan
Mon, Oct 3, 2005 at 11:47:21 AM | RE: importing autocad drawings
quiller
quiller Avatar
2.5 Stars: 3 Votes
I never have a problem importing dwg's. Check the scale of the drawing in AutoCAD first to insure it's correct and try importing it again.
Mon, Oct 3, 2005 at 11:53:10 AM | RE: importing autocad drawings
Xane
Everything is fine, just check scale and units which you import ...
Tue, Oct 4, 2005 at 1:52:06 PM | RE: importing autocad drawings
karok
I have had this happen before. Especially when importing surveys (the surveyor uses decimal units, so to get it to a correct scale you have to scale everything by 12). try to get it to the correct scale/ units etc in autocad, before you import it.
Thu, Oct 6, 2005 at 1:57:02 AM | RE: importing autocad drawings
Shanthi
Actually while importing to revit first we have to check the same units(metric, inches) is applied in both revit as well as in autocad. the second point is autocade file it is very easy your insertion point to be in 0,0 and apply the limits to the size of the drawing. so it will place exactly centre in your revit while importing and please check the file units should be matching then it is very easy to handle.
Fri, Jan 15, 2010 at 3:56:43 AM | importing autocad drawings
Kardiff
5 Stars: 3 Votes
You will need to check your units you drew your AutoCAD drawing inIf it was drawn in inches you'll need to get the units when you import to inches(i think it defaults to mm )additionally you'll need to make sure it was drawn to scalefor mm 1000 = 1mso if you drew a 4 x 4 square revit by default would pick it up as a 4mmx4mm square
So by checking in the drawing that appropriate numbers were used, and checked the units upon import the drawing should come in at the correct scale
- Just trying to help out while I wait in the office for my renders to complete
www.danrossiter.co.uk
Fri, Jan 15, 2010 at 10:27:49 AM | importing autocad drawings
TKennedy
4 Stars: 7 Votes
In the import dialogue box, try changing the Import Units from Auto-Detect to whatever your DWG units are. I've never had good luck with the auto setting.
Importing from AutoCAD - distant origins
Mon, Mar 17, 2008 at 6:00:27 AM
Importing AutoCAD Layer standards
Wed, Jul 11, 2012 at 8:19:21 AM
How to make Revit elevations look like AutoCad Drawings
Tue, Nov 27, 2007 at 9:11:36 AM
Revit looking Like AutoCAD
Tue, Oct 4, 2011 at 4:41:28 PM
How do I convert Revit drawings to AutoCAD drawings???
Fri, Sep 23, 2011 at 2:19:27 PM
Page generation time: 0.4865
