Forums >> Revit Building >> Technical Support >> SIR erland73!
Can you please fix the tires of your HUMMER where when rendered it appears to be white -->>>http://www.revitcity.com/downloads.php?action=search&keywords=hummer&user_name=&sort=score Ive tried all ive got to change it myself but then i failed..I'll wait for your reply on this matter thank you
Hey my friend, how are you?.....yep, I've seen some images with that issue, but it seems that is a RAC 2010 issue 'cause before I upload it here, I tried rendering it in 2009 & 2010 and worked for me, although sometimes in 2010 I've had that issue as well. Sure, I will fix it (I will upload it in 2010 version)...
Thank GOD! Your like a super hero, appears when needed haha! I'm just asking a whenever you have spare time of you to fix it, it's not that rush though...You are still kind as always, thanks in advance my friend been a long time.. thank you!!
Hi mr bean diesel...you can download the Hummer (fixed) now...BTW - sorry for the delay...
Edited on: Fri, Jun 11, 2010 at 8:30:28 PM
THANK YOU my friend! can you share how did you fix it if it's not that complicated? BTW this really means a lot, so thank you!
Do any of you have a RR Phantom 2007? I have searched all over the web for this car.
Revit Architectural Classes in Matara SriLanka |
Sat, Feb 16, 2019 at 8:49:08 PM
Request for help in cut and fill tool |
Wed, Sep 26, 2012 at 11:58:45 AM
PLEASE HELP!! WALL VISIBILITY/WORK PLANE ISSUE??? =( |
Sun, Jul 26, 2009 at 2:36:16 PM
Missing surface patterns in 3D |
Fri, Apr 10, 2009 at 12:14:08 PM
Problems measuring individual elements within Walls |
Fri, May 2, 2014 at 7:43:23 AM
Members: | 2098054 | Objects: | 23164 | Forum Posts: | 152290 | Job Listings: | 3 |
