50 Users Online (49 Members):
Forums >> Revit Building >> Tips & Tricks >> Error: Entry Point Not Found
Issue You receive an Error message when starting a Autodesk Revit 2011 product: Entry Point Not Found Solution There is a known issue when Buzzsaw Sync,build 2011.1.17.1590, is installed on the same machine as a Autodesk Revit 2011 product. After starting the Revit session, the first time you open or save a file in that session, you will receive an error message: Entry Point Not Found. If you encounter this error message, you should check your version of Buzzsaw Sync for updates and apply the most recent update. This issue has been resolved with build 2011.1.17.3401. To check for updates for Buzzsaw Sync, Right click on the Busssaw sync icon in the task bar and select Check for Updates To check your build number select About. This will show you a dialog box with the current build number installed. This is the original post from Autodesk: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15131969&linkID=9243099&CMP=OTC-RSSSUP01
Edited on: Sat, May 29, 2010 at 12:05:28 PM
new color scheme entry error |
Thu, Sep 18, 2014 at 1:42:54 PM
12
Pedestal for HC automatic entry door |
Fri, Jul 9, 2010 at 1:00:48 PM
Point Cloud location |
Tue, Apr 8, 2014 at 2:23:56 PM
Roof Covered Entry Problem |
Mon, Jan 31, 2011 at 1:58:30 PM
keyboard entry for inserting details or "blocks" |
Mon, May 4, 2009 at 6:43:25 PM
Members: | 2066493 | Objects: | 23085 | Forum Posts: | 152257 | Job Listings: | 3 |
